I am thinking about grabbing a Ford built diesel engine, input needed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 11 replies and been viewed 1624 times.
post #1 of 12 (permalink) Old 06-11-2010, 04:09 PM Thread Starter
I have a 1968 Ford crew cab and a Cummins I planned to mate together. However, I recently found a Ford built straight six diesel engine. I think it is for a marine application. Anyhoo, I sure would love to drop a Ford engine in that old Ford pickup. Here is the problem, I know nothing about them. I barely know enough about the Cummins to drop it in and get it running. The Ford engine is really the way I would like to go but I have to make sure it will fit my needs. I have been all over the internet trying to locate information but I think I am looking in the wrong areas. Can someone please guide or help me with this. My window on buying the engine is closing and I have to make a well informed decision quick.
These are the only numbers I have from the Ford engine:
REF 5503
TYPE 212C
post #2 of 12 (permalink) Old 06-12-2010, 12:42 AM
Super Moderator
nevrenufhp's Avatar
The main questionable part for me would be the pump, and it being a constant speed type. If it's based on the New Hollands, then it should be a fine & dandy engine. If the price is right, then go for it. Nothing wrong with a Ford engine in a Ford.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #3 of 12 (permalink) Old 06-12-2010, 12:52 AM Thread Starter
From what I have learned, it is a truck engine. The only issue is what all its missing. No pump, no turbo, no manifolds, no injectors, no plate for the transmission, no accessories. But... it sure is purdee.
post #4 of 12 (permalink) Old 06-12-2010, 01:12 AM
Super Moderator
nevrenufhp's Avatar
Then buy a core engine that has all that stuff, and you're set.
Dale
post #5 of 12 (permalink) Old 06-12-2010, 01:15 AM Thread Starter
Um, yeah...about that. It would seem that locating on of these engines now is not all that easy. I have a Cummins in a running and driving truck that I plan to use. I can only imagine what it would cost to get this one up and running. However, even though I know it will be hard and very costly, I still want to do it. How cool would it be to pop the hood on my 68 and see that 6.6?
post #6 of 12 (permalink) Old 06-12-2010, 01:21 AM
Super Moderator
nevrenufhp's Avatar
Mine's only 1 year older than yours. I know it would look awesome. There's a couple core 6.6's by me that go for around $500, and they ship
Dale
post #7 of 12 (permalink) Old 06-12-2010, 01:45 AM Thread Starter
It seems like everything is out west.
post #8 of 12 (permalink) Old 07-04-2010, 02:47 PM
little late to the game, but here goes. it's likely the ford engine you have found is the 6.6/7.8 series. memory serves me they used the same block, so either engine will be basicly the same size. the cummins would be an easier simpler swap, i did one on my gmc and it was a piece of cake. this being said, i would prefer the ford engine myself. the biggest issue with the ford engine, i think you will need a dog house in your truck due to length. also the transmission availability is very limited on this one. as for the engines themselves, lots of them in old school buses, and every now and again you find them very cheap on ebay in single axle trucks..
navistar45 is offline
post #9 of 12 (permalink) Old 07-04-2010, 04:40 PM
Super Moderator
nevrenufhp's Avatar
Actually the deck height is shorter on the 6.6, which makes it just a tad bigger than a Cimmins 6BT in height and length. Then, you got the pump on the pass side, and exhaust on the driver side to figure out.
Dale
post #10 of 12 (permalink) Old 07-04-2010, 05:01 PM Thread Starter
I had to step away from the one I found because it was missing everything. Being new in the crate did not off set the cost of coming up wiht a pump, turbo, manifolds, injectors, and so on. However I am still very interested in locating one for this swap. I have some time before I will get to the stage where I drop the engine in. So I am hoping to take my time and find the right deal for me. I would much rather open the hood on my 68 Ford crew cab and see a Ford smoker filling the frame rails.
Ford's new diesel truck engine to be built in Mexico, not Brook Park Monsterplow 2011+ 6.7L Power Stroke Diesel 19 09-07-2009 03:55 AM
Input needed from Biodiesel Brewers Tav Bio-Diesel/ULSD/Additives Discussions 3 01-17-2009 06:38 PM
FORD- diesel engine ??? thompsd General Ford Truck and Excursion 16 03-13-2007 02:58 AM
INPUT NEEDED- you decide the contest! Timbeaux38 Past Giveaways 11 10-18-2005 01:59 PM
Input Needed.....Please Look At This bigdraft 5.9L Cummins (1998.5-2002) 15 10-01-2005 09:02 PM
