Diesel Truck Forum - TheDieselGarage.com - View Single Post - What TURBO to go with?
View Single Post
post #8 of (permalink) Old 07-04-2009, 12:59 AM Thread Starter
Gee
Originally Posted by 4cstr View Post
First off, what is your build date? If you have an early 99 (build date prior to 12/98) you are going to need a new pedestal, spider pipe and intake manifolds. If you have a late 99...then a new turbo will just drop in.
Kool....my build date is 6/99.
How much more can I expect from the Modded H2E over the Garrett GTP38R?
Does one have more boost lag in the lower RPMS and/or does one pull harder on the high end? Which of the two is LOUDER?
99 F250 PSD, AFE Stage II,Wicked Wheel,Foil Delete,MBRP 5" Exhst,Power Slot Brakes,Evo II Tuner,& Dr.Evil Trans w/Converter.
Still braking in the motor at 390k :
Gee is offline
