Here is my problem. I have a 2003 LB7 with 35x12.50x20, and one of those torsion key leveling kits :bang. When I put the tires on about 20,000 miles ago the tie rods were bad, causing the alignment to fail. The problem was solved by putting new tie rods, tie rod ends, and I also put the tie rod sleeves on too. Now I have noticed that my alignment seems to be off. My steering wheel is a few degrees off. When I inspected my tie rods the passenger side feels tight and I cannot wiggle it. The driver's side has some considerable play in the tie rod end (closest to the wheel). Any ideas on how to fix. I am assuming that a new tie rod and alignment might be in order, but what are some other options I have heard that cogntio kit works wonders, but is pretty pricey. Thanks
