f350 engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pasquina, this thread has received 0 replies and been viewed 3104 times.
post #1 of 1 (permalink) Old 08-08-2010, 05:49 PM Thread Starter
f350 engine light
Hi guys, need help to reset the check engine light on my 2007 f350 diesel,
i'm using an Actron cp9135 OBD from Discount and doesen't turn on as it should, the OBD it works on my other car. I check for voltage on pins 4 and 16 of the DLC and there is no voltage on pin 16, pin 4 has continuity to ground. The check engine light came on after showing up in my dash display a problem with my sending unit and water in fuel (bad idea try to save a buck on fuel, cheap fuel doesen't pay). I cleaned the tank, freed and cleaned the sending unit and everything seems to be working properly. Do I have a problem with the truck wiring or do I need a different OBD?
pasquina is offline
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 05:46 AM
Price on HID light kit for OBS F350 SoGrand Supporting Vendors Forum 0 08-07-2009 03:05 PM
Light bar for F250 F350 jayshaw638 Whats Been Sold 6 04-23-2008 03:36 AM
Tail light wiring for 08' f350 sd srw bludragon 2008-2010 6.4L Power Stroke 4 07-21-2007 07:56 PM
00' F350 No Start, No Wait to Start Light or SES light Huckster 1994-2003 7.3L Power Stroke 8 10-27-2006 08:38 PM
