Sled Pull, Feb. 2nd - Bradenton - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordt, this thread has received 1 replies and been viewed 594 times.
post #1 of 2 (permalink) Old 01-22-2008, 12:29 PM Thread Starter
fordt
February 2, 2008
Desoto Super Speedway
21000A East State Road 64
Bradenton, FL 34202
Weigh In - 3pm
Drivers meeting 4:45pm
Start Time - 5pm
DIESEL RULES:
Stock Diesel Class (ST)
This class is for the daily driver with completely stock motor and drivetrain.
Aftermarket Computers/Programmers, Exhaust and Air Intakes are permitted.
Aftermarket Turbos and Injectors not permitted.
Hitch must be stock and in factory location.
Rear suspension may not be blocked
Hanging weight is prohibited.
Street Stock Diesel (SS) @ 8000 lbs
This is for the daily driver with some aftermarket modifications.
Stock Turbo only.
Rear suspension may be blocked
Hanging weights are permitted.
No Nitrous or Propane.
2WD's running in this class may run 31" hitch height.
Aftermarket computers or programmers are permitted,
A stock transmission & transfer case only, fuel injection pump is limited to a stock appearing, pulling hitches are allowed, u-joint covers and driveshaft loops are required on ALL trucks!
Outlaw Diesel (OD)@ 8000 lbs
This is for the trucks with considerably more modifications.
Aftermarket Turbo and Injectors are permitted.
Pulling hitches allowed.
Aftermarket computers or programmers are permitted, driveshaft loops and u-joint covers and kill switches are required on ALL trucks , NOS and/or propane allowed!
post #2 of 2 (permalink) Old 01-30-2008, 12:51 PM
I'll be there:squish .
http://www.youtube.com/watch?v=sMipqDz1ZAw
2005 dodge 3500, qc, drw, 4x4 flat bed, cummins edge hot w/A2, 5" mbrp turbo back, stage II afe intake, tracton bars, 12000 lbs hitch, BD lift pump, suncoast converter.
http://profile.myspace.com/index.cfm...ndid=352446226
MoPower05 is offline
