Portable Generators - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ohio Eddie, this thread has received 16 replies and been viewed 5259 times.
post #11 of 17 (permalink) Old 04-18-2010, 10:03 PM
BillsFan's Avatar
Another vote for Honda.
We use a EU3000i to run our Negotiator van at work. We went with the Honda because of the reliabilty, clean electricity ($10,000 worth of electronics in that van) and because it's wicked quiet.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
The Following User Says Thank You to BillsFan For this addition to TDG:
Ohio Eddie (04-24-2010)
post #12 of 17 (permalink) Old 04-23-2010, 03:40 AM
pyro2nite's Avatar
Honda 2000i is what I use. If you are using the AC a 3000i is a must. With it running tv/sat and lights, the 2000i will run about 10 hours on a gallon of gas. Very quite, even under load. You can pick them up new on ebay for less than 1000.00
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
The Following User Says Thank You to pyro2nite For this addition to TDG:
post #13 of 17 (permalink) Old 01-06-2012, 01:58 PM
buffalobob's Avatar
i got a champion 4000 watt from TSC for $300. ran constantly for 12 days, ran for 12+ hours on a 4 gal tank and ran everything in my toy hauler. also with it sitting on the ground outside, it was nearly impossible to hear
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #14 of 17 (permalink) Old 01-13-2012, 01:05 AM
Dodgefarmer's Avatar
Had a yamaha 2800 until somebody needed it worse then I doelmerfudd
Now need to look for another one. I did find that 2800 was not enough to run AC and Micro at the same time
singles club # 198
Dodgefarmer is offline
post #15 of 17 (permalink) Old 07-03-2012, 01:57 AM
dieselgeezer
I've had the Honda EU6500 for several years. It's never failed to start on the first crank. It lives in the bed of my truck. IMHO you get what you pay for in generators.
dieselgeezer is offline
post #16 of 17 (permalink) Old 07-03-2012, 02:57 AM
Weld engineer's Avatar
Honda eu2000. Inverter technology is the way to go for fuel efficiency and quiet operation. The engine rpm varies due to load since it is not a traditional power plant. Traditional generator has to be governed at set rpm to give you 60 Hz AC power. Move up to the 3000 if you want to run Air or get the parallel kit and 2x 2000's. Do not waste your money on a junk generac or other Chinese knockoff. I tried a generac 2200 and it caught on fire. They gave me all my money back and I bought a Honda. There is a reason everyone has em. They work forever. Made in Japan but i'll take that over china anyday.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #17 of 17 (permalink) Old 07-11-2019, 03:00 AM
"Fuel usage is not important for many, but gas is the most common, diesel the most efficient, propane cleanest burning. With that said you may need to consider where it will be placed I hate diesel fumes, propane burning should be mostly safe if exhaust is consumed."
With people going more eco-friendly right now I think propane is a good choice.
About the Honda, not sure with the price but this is my first time knowing that it is good compared to other brands.
jeephoarder is offline
Portable Dyno in Missouri?? 95psdF250 Dyno Board 1 09-01-2006 03:50 PM
Can the portable shelters take high winds Duke The Parking Lot 6 05-31-2005 03:21 PM
