Winch advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BombDocDiesel, this thread has received 8 replies and been viewed 2554 times.
post #1 of 9 (permalink) Old 02-02-2011, 05:50 PM Thread Starter
TDG Mafia Goon
BombDocDiesel's Avatar
Winch advice
So I decided I want a winch. I have Road Armor stealth bumpers.
I'm debating between a Warn XD9000i and a Warn PowerPlantHP 9.5.
I like the idea of on-board air and the price considering what I see on-board air systems going for. Those of you will any experience with this please help me out. Should I stick with a straight winch, go with the dual purpose or maybe look at even bigger winches?
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #2 of 9 (permalink) Old 02-02-2011, 07:18 PM
Administrator
fordt's Avatar
Images: 5
What do you plan on doing with the winch?
I keep thinking about getting one, I know I won't go with anything less than a 12K lb capacity, but my truck weighs a good bit more than yours.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
The Following User Says Thank You to fordt For this addition to TDG:
BombDocDiesel (02-02-2011)
post #3 of 9 (permalink) Old 02-02-2011, 07:32 PM Thread Starter
TDG Mafia Goon
The pig has gained a bit of weight. Since I have one street screamer I want this one to be a bit more utilitarian. It's not an off-roader but I would like to be able to self-recover. Plus my truck looks goofy with that huge hole where the winch mounts.
I just found the bigger Warns as well. I was going by the recommendations of what fits in the Road Armor. It looks like anything winch with a standard bolt pattern can go in there. I like the idea of being able to use a pulley block to get a 2:1 on the line. I don't like the idea of pulling 400+ amps.
I did find a 12K Smitty pretty cheap. I had a little Smitty on my Jeep a long time ago. I was leaning heavily toward the Warn because it's made here.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #4 of 9 (permalink) Old 02-02-2011, 10:03 PM
Pardue the Traveler
New 0mega's Avatar
Your defiantly going to want either a minimum 12k or 15k+ pound winch.
Here's a warn 12Klb that gives you both a winch and air compressor in one.
http://www.warn.com/truck/winches/powerplant_hd.shtml
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
post #5 of 9 (permalink) Old 02-02-2011, 10:15 PM Thread Starter
TDG Mafia Goon
I was looking at those as well. I'm not sold the idea of a dual purpose. I looked into the other companies that make them and both of the other companies discontinued those products. It also looks like I can go Viair and have on-board air and a winch for less money. I'm hoping someone chimes in that has experience with those PowerPlant models.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #6 of 9 (permalink) Old 02-03-2011, 12:30 AM
I tend to over engineer everything I do. I decided on the Warn 16.5K just because I knew sometime down the road, when I finally had my truck setup the way I wanted, that it would close in on the 10K weight. Too close for a 10-12K winch capacity for me. Batteries, alternator and cables are in place to handle the draw. Air compressor will be separate. Everything functional for onroad use.
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline
The Following User Says Thank You to boobin For this addition to TDG:
BombDocDiesel (02-03-2011)
post #7 of 9 (permalink) Old 02-03-2011, 01:00 AM Thread Starter
TDG Mafia Goon
I just found a Smittybilt 12K for under $400. I'm not getting any heavier, save maybe 40 pounds for on-board air.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #8 of 9 (permalink) Old 02-03-2011, 02:26 AM Thread Starter
TDG Mafia Goon
Well, the Smitty was too good to pass. I looked all day and the only way to find a better deal was to look for a used model. I will post pics when I get it.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 9 (permalink) Old 02-03-2011, 03:22 AM
ADMIN/MAFIA
neeltburn's Avatar
Let us know how it goes Josh, I am a big Warn fan.. keep looking at them for the Rubicon...but that price tag keeps me wondering if I will really need it..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Need Winch Help!!! F3600 4X4 Offroad Forum 3 06-28-2010 02:28 AM
I need some big winch help. Lonesome7.3 Towing and Hauling 28 04-19-2009 09:08 AM
Winch Bad Habit 2008-2010 Body & Suspension 29 01-28-2009 01:52 AM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
winch imported_coalfed 5.9L Cummins (2003-2007.5) 1 02-01-2008 12:39 AM
