1997 Cherokee ax-15 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fast_and_furious, this thread has received 7 replies and been viewed 3706 times.
post #1 of 8 (permalink) Old 12-06-2009, 05:24 PM Thread Starter
1997 Cherokee ax-15
Alright i got a 1997 cherokee with a 6cyl 5 speed AX-15 tranny. The jeep is 2wd and im wondering if i can use this tranny and put it in a 4wd jeep? What would all be involved?
Thanks
03 f-350 cclb srw Oilguard bypass filter sct (doug and spartans tunes) boost,trans,pyro only problems 1 injector and a couple of reflashes runs flawless (knock on wood)
New Toy 97 dodge 2500 4x4 12 valve 4in turbo back exhaust and stock plate FF for now.
Mods to come in the near future
Built Trans, DV, 4k gsk, injectors??, studs
Fast_and_furious is offline
post #2 of 8 (permalink) Old 12-06-2009, 06:38 PM
Pardue the Traveler
New 0mega's Avatar
what's the 4x4's year? If your swapping to another '97 or newer then all you need to do is swap tail-housing from the 2wd to the 4wd. If not then there's a bunch of things you need to do.
Singles Club member #250
New 0mega is offline
post #3 of 8 (permalink) Old 12-06-2009, 08:59 PM Thread Starter
A person wanted to buy both the engine and the tranny out of the 97 and put them into his 1990 wrangler. What would he need to do?
Thanks
post #4 of 8 (permalink) Old 12-07-2009, 05:03 AM
Pardue the Traveler
New 0mega's Avatar
You'll have to swap the 2wd tail shaft with a 4x4 version of your transmission so you can mate it up to the transfer case. You'll have to make sure you take the electronic control units from the '97 and put them in to the '90. The engine might not fit, so some custom fab engine mounts would be need and a custom transmission crossmember.
post #5 of 8 (permalink) Old 12-07-2009, 01:08 PM Thread Starter
OK thanks a lot and one more question. Since the transmission is 2wd can he still use the electronics for that tranny or will he need one from a 4wd vehicle?
Thanks
post #6 of 8 (permalink) Old 12-07-2009, 05:13 PM
Pardue the Traveler
New 0mega's Avatar
He can use the 2wd electronics for the transmission.
The Following User Says Thank You to New 0mega For this addition to TDG:
Fast_and_furious (12-08-2009)
post #7 of 8 (permalink) Old 12-08-2009, 01:17 AM Thread Starter
Thanks new 0mega
post #8 of 8 (permalink) Old 12-08-2009, 01:48 AM
TDG Mafia Goon
BombDocDiesel's Avatar
IIRC, you will need a new tail housing and main shaft.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
The Following User Says Thank You to BombDocDiesel For this addition to TDG:
Fast_and_furious (12-09-2009)
Cherokee 57 CHEROKEE 57 1994-2003 7.3L Power Stroke 3 06-01-2009 01:25 PM
Diesel Grand Cherokee jonxmartini General Diesel 0 03-24-2009 02:01 AM
'93 Cherokee >> Diesel.. plausible? Crawdads Diesel Conversion 15 05-03-2008 11:10 PM
F/S 1997 Jeep Cherokee Sport 4.0l 2dr 4x4 psdexcursion Whats Been Sold 1 11-10-2007 12:25 AM
Jeep Grand Cherokee Crd BROKER The Parking Lot 4 09-09-2006 02:03 AM
