Having an issue with my '03 when I hammer down on it on the fly (usually between 35-50 mph) it starts to act like it is flooding and won't go over the rpm's it ramped up until I let up the accelarater and ease back into it to get up to speed. I have airaid air intake, Edge Juice w/ monitor, 4"MRBP turbo back. When I put it on stock it doesn't do it as frequently however it is doing it regularly on level 3 . Any clues?
fuel filter getting clogged would be my guess, or the mass airflow sensor getting dirty/oily, I would lean towards either as they are rather simple to check both. Hope that helps.
The edge module may be defueling due to excess EGT's, Boost, or transmission slippage, check your edge manual to see how you can change those defuel points
If the engine revs up then its a transmission flare because the allison hasn't learned to deal with the extra power that you adding with the Edge, allow the transmission to learn a new tune well before abusing it
And like Dux2Bux said change your fuel filter and check your MAF sensor
Related Threads
The Diesel Garage
1.2M posts
57.3K members
Since 2005
