OASIS REPORT PLEASE
985 views 1 reply 2 participants last post by  fredwilliamson
#1 ·
I need a OASIS report for my truck vin# 1FTSW21R88EB03455 please!!!
#2 ·
OASIS RESULT: 1FTSW21R88EB03455 USA: EN 16-JANUARY-2013 / 05:50:48 EST/ APP2
Local Time: 16-JANUARY-2013 / 3:50:52 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.4L Diesel V8 Twin Turbo
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 8F716A0A
PAINT COLOR: Charcoal Beige
PAINT CODE: T7
RADIO: Prem AM/FM Stro/CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 8 X 20" Prem Forged Pol Alum Wheel
FRONT TIRE: LT275/65R 20E A/T BSW
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Comments CUSTOMER STATES THE VEH PULLS TO THE LEFT, SOLD VEH. CUST. COMPLAINED ABOUT IT ON TEST DRIVE. SPL ORDERED TRUCK.
Tech Comments42 TEST DROVE VECH. FOUND IT TO DRIFT LEFT PERFORMED ALLIGM. FOUND TOE OUT LEFT AND RT SET TOE AND RETEST DROVE OK AT THIS TIME E
Customer Comments CUSTOMER STATES THE VEH MAKES A ROAR LIKE A JET ENGINE, THE TRANS. FEELS LIKE IT IS LABORING AND THE FUEL ECON. IS ALL OVER THE PLACE...11 MPG, THEN 12 MPG, THEN 10 MPG, AND BACK UP TO 12,
Tech Comments REPROGRAM PCM ACCORDING TO TSB 07 17 3...RECHECK AND ROAD TEST...MO 5191...
Customer Comments CUST STS HAS TO JUMP START EVERYTIME HE SHUTS IT OFF
Tech Comments CHECK ALTERNATOR OUTPUT,FULL FIELD TEST,TEST FOR ELECTRICAL DRAW IN MILLIAMPS,CHECK BELT AND TENSIONER,LOAD TEST BATTERY VEHICLE STARTED.PERFOMRED STARTING CHARGING AND BATTERY TEST BATTERIES FAILED.DTC 114JT0J3S1G1L ACES XE64L DTC 10SJSEATS5001 ACES XE14L.R&R BOTH BATTEROES ON DIESEL.RAN STARTING CHARGING AND BATTERY TEST.CHECKED OK.
Customer Comments CUST STS CANT USE AUTO HEADLIGHTS ANYMORE,THEY DONT SHUT OFF
Tech Comments REPROGRAMMED IC OER RECALL 08B07.MONITERED PIDS RECHECKED OEPRATION OF AUTO LAMPS.LAMPS ARE WORKING PROPERLY AT THIS TIME.
Customer Comments PERFORM RECALL 08C04
Tech Comments PERFORMED RECALL 08C04
Customer Comments CUST STS HE HAS TO KEEP ADDING COOLANT TO THE RESEVOIR
Tech Comments FOUND VEHICLE WITH DEGAS BOTTLE LOW.TOPPED OFF COOLANT WITH WATER.PRESSURE TESTED COOLANT SYSTEM.FOUND RADIATOR LEAKING.R/I GRILL,COOLERS,CAC HOSES AND FAN SHROUD.R&R RADIATOR.R&R COOLANT.PRESSURE TESTED NO OTHER LEAKS FOUND.TEST DROVE VEHICLE.CHECKED COOLANT TOPPED OFF COOLANT NO LEAKS FOUND.
Customer Comments PERFORM RECALL 08B06
Tech Comments INSTALLED RECALL KIT AS PER RECALL 08B06
Customer Comments PERFORM RECALL 08C01
Tech Comments R&I SEAT COVER MOVED INSTALLED BRACKET FOR SEAT BACK FRAME AS PER RECALL 08C01
Customer Comments CUSTOMER STATES THE RAD COOLING FAN HAS BEEN COMMING ON MORE OFTEN...CHECKED COOLANT LEVEL...LOW. LOOKS LIKE COOLANT LEAK UP FRT OF THE ENGINE SOMEWHERE...TOPPED OFF COOLANT AND BROUGHT VE
Tech Comments LEAKING ORING CC D8 ADDRESS CONCERN DIAG PRESSURE TEST COOLING SYSTEM RR LOWER RADIATOR HOSE REPLACE ORING IN HOSE FITTING REFILL COOLING SYATEM TEST DRIVE M O 28493
Customer Comments CUSTOMER STATES THE BRAKES SQUEAK A LITTLE...BE SURE TO DO MULTIPOINT REPORT ON BRAKES. ADV. PROGRAM CODE P18,CUDLS#1577472431.
Tech Comments BOTH REAR CALIPER ARE SLOW TO RELEASE AND DRAGGING BOTH CALIPER PISTONS ARE BINDING IN THE HOUSING, WILL NOT RETREAT TO FULL BACK POSISTION, CANT FIT PADS IN PLACE. REPLACE THE REAR CALIPERS BLEED THE SYSTEM ROAD TEST...GOOD.
Customer Comments CUSTOMER STATTES RECALL 11B23...PCM RECALIBRATION, CUST SAID PCM IS STOCK.
Tech Comments UPDATE THE PCM AND IC PER THE RECALL
