1 - 15 of 15 Posts
My 450 just seems to have no power. If I am easy on the throttle it's fine but if you rev it at all it has nothing. I am very new to the 7.3 so go easy.
The truck is fine in low rpm use even plowing with my 10' plow is no problem at all, it pushes with ease but get on the road and go over 2000 rpm and just no power.
G
If you are on the road and going over 2k rpm's...what speed are you? Reason I ask is that with that 10' flow plow on the front...you have a huge frontal surface area in which to push.
Has the Check Engine Light lit up or anything? Can you get it scanned for any possible codes.
Discussion Starter · #3 ·
Even when your on a back road and you rev over 2k it does the same thing, once it shifts and the rpm drop it's fine.
No codes or check engine light.
Yea id definetly change your fuel filter if you havent already!
checking out the fuel filter is worth a try
other than that it is probably your HPOP cannot keep up with the demand for oil to fire the injectors are the higher power levels
Discussion Starter · #7 ·
Fuel filter has about 5k on it. The exhaust sounds odd when it revs up over 2000 rpm as well.
TDG Mafia #95
Well if you've got a weird sound coming out of the exhaust I would almost have to bet that your Exhaust Back Pressure Valve (EBPV) is closing. If its cold, its running in normal operation, and judging by you plowing snow, its ok. To test this, look underneath the pedestal. There is a plug under the pedestal that controls the EBPV. Unplug it and see if you notice any more power.
this is what i was getting at, it probably explains his power loss
:agreed: Ebpv may be your prob.
Discussion Starter · #12 ·
I will try it and report back.
Discussion Starter · #13 ·
So new fuel filter, unplugged the ex valve and no difference. Sounds and drives the same.
Just to be clear, the plug has a metal wire clip locking it in place?
MAFIA MEMBER 106
10-4 thats the one does it smoke? is your air cleaner in good shape?oil level ok?afer all of these i would look into a map sensor but thats a long shot
strokin now cummin later!
do you have any gauges such as a pyro or boost. so see if its a air or boost pressure problem.
1 - 15 of 15 Posts
