Here's one that's got me absolutely stumped... Customer has an '01 T800, R/R Brake light won't come on.
The details...
L/R lights all work properly stop/turn/running/reverse...
R/R lights all work as above except the brake function... lamp is good as the turn works.
Tried new turn signal switch and it meters out as showing voltage to the R/R lamp wire on the connector with bakes applied.
At the junction box on the back of the frame it shows blinking voltage on the green when turn signal is operating but nothing with brakes applied, again new LED lamps, left side works 100%, right side everything except the brake function, grounds are star grounded to the frame and carried through the harness.
Any ideas ????
Thanks,
gb
The details...
Any ideas ????
Thanks,
gb
