2002 F-350 LARIAT 7.3L 6 SPEED MANUAL TRANS CREW CAB 8' SINGLE REAR AXLE NO MODs 6'' SKYJACKER LIFT W/STRAIGHT EXHAUST
no keyless entry
no power door locks even at 5mph
no interior lights when a door opens only when key is removed from ignition
door ajar light on cluster stays on
no auto exterior light function only manual
no seat belt alarm or parking brake alarm when driving
radio does not turn on with ignition only manually but will turn off after 5 minutes also can be turned on with out key in ignition
air vent is stuck on defrost mode no matter what mode its on A/C and heat still works through defrost vent
check engine light is on but its from parking brake install and could not get a code read, people told me it was a glitch. from these forums I see most OBD2 scanners cant read my powerstroke codes.
I have checked all fuses and for lose connections nothing.
I had my bumper (rear) swapped after I got rear ended. he dented it so I used another one I had. anyway they welded a bracket on my truck for the bumper. when I got my truck back these were new problems all at once.
HELP with the above issues instrument cluster or VSM issue and check light from brake install would be helpful too. there could be codes for several of these issues but I have not had them checked with a scanner that can read them. I'm ordering the AUTOENGINEUITY for ford 7.3l this week so I will be capable do so then.
any help, ideas, or solutions would be great. thank you
