Printable View (7 KB)
TSB
04-24-11 MOMENTARY RETURN TO IDLE DURING AGGRESSIVE ACCELERATION - DIAGNOSTIC TROUBLE CODE (DTC) P0123 - 7.3L ENGINE
Publication Date: November 24, 2004
FORD: 2001-2003 Excursion, F-Super Duty
ISSUE:
Some 2001-2003 F-Series Super Duty and Excursion vehicles equipped with the 7.3L engine and a non-adjustable (fixed) accelerator pedal, may exhibit the malfunction indicator lamp (MIL) illuminated intermittently, and a momentary return to idle during aggressive acceleration. Diagnostic trouble code (DTC) P0123 will be stored in the powertrain control module (PCM) when the condition occurs, but may be cleared after forty (40) vehicle warm up cycles if no repeat conditions occur.
ACTION:
If normal PC/ED Manual diagnostics do not identify a root cause, install a revised fixed accelerator pedal. Refer to Workshop Manual Section 310-02.
PART NUMBER PART NAME
1C3Z-9F836-BA Pedal - Accelerator
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
042411A Replace Accelerator Pedal (Includes Time To Check And Clear Diagnostic Trouble Codes) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
9F836 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2004 Ford Motor Company
