1 - 12 of 12 Posts
· Junior Member
Those of you out there that have been running a mechanical fan clutch and fan blade on your swap which setup did yall use? Does it keep the A/c cool at idle and what not? Thanks for any help with this matter.
· Junior Member
If you are going to spend any money on the fan system I would seriously look into a Horton electric thermatic fan.
Just a thought!
· Junior Member
Discussion Starter · #3 ·
I would really like to stick mechanical fan setup. Seems to work well. I have a very bad experience with electric fans on my rock crawler
· Junior Member
Discussion Starter · #6 · (Edited)
What adapter? does ur fan come really close to your tach sensor kit? What motor are you running?
· Junior Member
I'm running the stock 12V fan and the 6.0 shroud with stator deleted. but I have not hooked up my ac yet so it will be a few weeks before I can give you any input. I know you are having issues with the ac at stops, so can't you just add a small pusher fan in front of the condensing coil to help when you are stopped in traffic? Hate to see you sell it just because of this.
· Junior Member
Discussion Starter · #10 ·
Well I got the fan Issue solved now the ac will not come on.
· Junior Member
Discussion Starter · #12 ·
Just wanted to say thanks for the insight. My a/c works great! It was the high pressure switch. Blows 39*
1 - 12 of 12 Posts
