Printable View (8 KB)
TSB
05-20-3 OIL PAN CORROSION - 7.3L OR 6.0L
Publication Date: September 22, 2005
FORD: 1999-2006 E-Series, F-Super Duty
2000-2005 Excursion
2000-2006 F-650, F-750
This article supersedes TSB 03-21-46 to update the affected engines and vehicle model years.
ISSUE:
Some vehicles equipped with the 7.3L or 6.0L Diesel Engine may exhibit engine oil pan corrosion when operated in high salt content/corrosive environments. If the customer is concerned with this cosmetic issue, the following procedure may be used to resolve the condition.
ACTION:
Inspect the oil pan. If corrosion is detected use Motorcraft High Temp Anti-Corrosion Coating, Part Number PM-13-A, to service. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Clean the oil pan off with a solvent to remove any dirt and oil. Using a 3" angle grinder with a 36 grit disc, grind off all loose corrosion. Blow off with air. Wash the pan with soap and water and let dry. Brush the anti-corrosion coating on the oil pan. Allow coating to dry fully before operating the vehicle.
PART NUMBER PART NAME
PM-13-A Motorcraft High Temp Anti-Corrosion Coating
WARRANTY STATUS:
Information Only - Not Warrantable
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2005 Ford Motor Company
TDG Mafia Member # 37
Squatch, first off thanks for all the TSB's. Would Ford be obligated to do this to my truck with 103,068 miles on it? Gene :mafia
"WARRANTY STATUS:
Information Only - Not Warrantable" guess that means for paying customers only
TSB
2000-2005 Excursion
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
yeah says not warranty. I like how it says not to be done by the do it yourselfers, real indepth process. Personally id sand it the best I could, and use por 15, never have another problem.
Thanks guys for the replies, I guess I'll have to do it myself. It's just with my back still giving me fits, was hoping to get it done while it didn't require anything from me but driving it to the dealer. Thejdman04, I was actually planning on using POR15, that there is some good stuff. Gene ;mafia
