Printable View (47 KB)
TSB
06-22-9 6.0L - MIL ON WITH DTC P2138, P2139, AND P2140
Publication Date: October 23, 2006
FORD: 2005-2006 E-350, E-450
2005-2007 F-Super Duty
This article supersedes TSB 06-13-10 to update the vehicle model years coverage.
ISSUE:
Some 2005-2006 E-Series vehicles built through 6/12/2006 and 2005-2007 F-Super Duty vehicles built through 6/5/2006, equipped with a 6.0L diesel engine may exhibit the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P2138 P2139, and P2140.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release IDS-45.8 and higher. This new calibration is not included in the 2006.9 DVD. This calibration contains a revised strategy to eliminate the occurrence of a false P2138, P2139, or P2140. Calibration files may also be obtained at www.motorcraft.com. Follow normal diagnostics if any of these DTCs still occur after reprogramming.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
062209A 2005-2007 F-Super Duty 6.0L 2005-2006 Econoline 6.0L: Check For DTCs And Reprogram The PCM (Do Not Use With 12650D, 12650D84) 0.7 Hr.
MT062209 Use SLTS Operations If Available; Claim Additional Diagnosis Or Labor Performed As Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
recalem 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2006 Ford Motor Company
