stay running (clicking) after u turn off the truck ??
also the exhaust smell like raw diesel strong!??
thanks
the after cycle of injectors is part of a flash so it is normal (usually lasts 5-10 secs or so.)
:whs This flash cycles the injectors after you turn the truck off to get oil out of the top of the injectors(spool valves) so that the truck will have easier cold starts. The latest reflash is the inductive heating flash which i now have.
recommend getting the inductive heating flash . instead, seems to work a bit better.
Discussion Starter · #5 ·
So is this a stock ecu flash?, or aftermarket?, do I need to have a update flash done ?
Got 3 other friends and there truck doesn't what my trunk does but ??
if you're under warranty go to the dealer and complain about having cold start up issues and you want the latest flash. the end.
yes its a stock flash no aftermarket.
It's just an updated stock flash from a ford dealership
