Printable View (47 KB)
TSB
06-26-5 KING RANCH CREW CAB MODEL ONLY - WHITE CORROSION ON RUNNING BOARDS
Publication Date: December 19, 2006
FORD: 1999-2007 F-Super Duty
ISSUE:
Some 1999-2007 F-Super Duty King Ranch Crew Cab vehicles may exhibit white corrosion on the running boards. It is not necessary to replace the entire running board assembly for this concern. Only replace the diamond plate.
ACTION:
Follow the Service Procedure steps to replace the diamond plate.
SERVICE PROCEDURE
Remove all ten (10) nuts from under side of running board.
Replace Diamond Plate
Secure with all ten (10) nuts and torque 16 lb-in (1.8 N-m).
PART NUMBER PART NAME
XC3Z-16A470-AA Step Assembly
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
062605A 1999-2007 F-Super Duty King Ranch Crew Cab: Replace The Diamond Plate Insert On ONE Running Board 0.4 Hr.
062605B 1999-2007 F-Super Duty King Ranch Crew Cab: Replace The Diamond Plate Insert On BOTH Running Boards 0.5 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
16450 d4
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2006 Ford Motor Company
