1 - 20 of 45 Posts
Mafia member #105
Well it won't be much longer I almost have all my parts.Here's some pic's
Mafia member #105
7/21/08
Here's some pic's of what we have done going slow with other things getting done this weekend.
Mafia member #105
Found a mix up on part #97209622 there the main cap bolts but there for the older motors you must check the tops of your main cap bolts before getting new one from dealer,the older bolts are flat on th ehead the newer ones have a 0 in the head. I ordered mine from dealer and the gave me the #97209622, The LBZ is #98019464 there longer.
Reuse your old main bolts for line hone and plasti gauge, mafter that use the new bolts, I have to swap the main bolts out since the ones I got from gm are 4 thousand to short.Use the new part # 98019464 thats the ones for LBZ, We had friend that had a snap on one, I found one at autozone fo 10 bucks we checked with the snap on one and it works the same.
Mafia member #105
Discussion Starter #4 (Edited)
7/23/08
Mafia member #105
Mafia member #105
Mafia member #105
Mafia member #105
Well she's sealed up and lubed.
Mafia member #105
7/26/08
Pic of small work space lol
Mafia member #105
7/27/08
Mafia member #105
She's Alive again
Born on July 27, 2008, 11:59:02 PM
Mafia member #105
Discussion Starter #13
Mafia member #105
Discussion Starter #15
i've seen them before but never really sat and looked !
was a fun 30 minutes !
~ FYI ~
link in your sig isn't working for me.
Thank You I fixed it.
Mafia member #105
Discussion Starter #17
Na I had everything I post on my other hang outs saved made it easy to replace lol.Or you mean working on the truck lol not that bad looks like more then it is we had 59 hrs into doing everything.
Diesel Mafia #67
may-b its me cuz im use to working on 6.0's and cummins... but the d max looks very crammed in there....... Yes the 6.0's looked crammed... but as soo as you take out the fan shroud and turbo (3x) 10mm bolts its a cake walk.... None the less im not going to rain on your parade I know you have fun I know your truck is fast.. :thumbsup
Hey wheres the carnage pics:slap
Mafia member #105
Discussion Starter #19
LOL atleast we don't have to remove the cab to do the head gaskets lol.
Here's the link to the carnage http://www.thedieselgarage.com/forums/showthread.php?t=669
Gone Fishin...
Wow man, your just an engine building machine! Awesome pictures and info, thanks for sharing.
1 - 20 of 45 Posts
