Mafia member #105
Service Information
2006 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Engine | Engine Mechanical - 6.6L | Specifications | Document ID: 1651785
<HR>
Fastener Tightening Specifications
<TABLE width="95%" border=1><TBODY><TR><TH vAlign=center align=middle rowSpan=2>Application
</TH><TH vAlign=center align=middle colSpan=2>Specification
</TH></TR><TR><TH vAlign=center align=middle>Metric
</TH><TH vAlign=center align=middle>English
</TH></TR><TR><TD vAlign=center align=left>A/C Compressor Bolt
</TD><TD vAlign=center align=middle>50 N·m
</TD><TD vAlign=center align=middle>37 lb ft
</TD></TR><TR><TD vAlign=center>Air Cleaner Outlet Duct Clamp
</TD><TD vAlign=center align=middle>8 N·m
</TD><TD vAlign=center align=middle>71 lb in
</TD></TR><TR><TD vAlign=center>Air Conditioning Compressor/Power Steering Pump Bracket Bolt
</TD><TD vAlign=center align=middle>46 N·m
</TD><TD vAlign=center align=middle>34 lb ft
</TD></TR><TR><TD vAlign=center>Air Inlet Tube Nut
</TD><TD vAlign=center align=middle>25 N·m
</TD><TD vAlign=center align=middle>18 lb ft
</TD></TR><TR><TD vAlign=center>Battery Cable Bracket Bolt
</TD><TD vAlign=center align=middle>12 N·m
</TD><TD vAlign=center align=middle>106 lb in
</TD></TR><TR><TD vAlign=center>Battery Cable Bracket Nut
</TD></TR><TR><TD vAlign=center align=left>Bypass Pipe Bolt
</TD></TR><TR><TD vAlign=center align=left>Camshaft Gear Bolt
</TD><TD vAlign=center align=middle>234 N·m
</TD><TD vAlign=center align=middle>173 lb ft
</TD></TR><TR><TD vAlign=center align=left>Camshaft Position Sensor Bolt
</TD><TD vAlign=center align=middle>10 N·m
</TD><TD vAlign=center align=middle>89 lb in
</TD></TR><TR><TD vAlign=center align=left>Camshaft Position Sensor Exciter Ring Bolt
</TD><TD vAlign=center align=middle>9 N·m
</TD><TD vAlign=center align=middle>80 lb in
</TD></TR><TR><TD vAlign=center align=left>Camshaft Thrust Plate Bolt
</TD><TD vAlign=center align=middle>22 N·m
</TD><TD vAlign=center align=middle>16 lb ft
</TD></TR><TR><TD vAlign=center>Charged Air Cooler Bolt
</TD><TD vAlign=center align=middle>21 N·m
</TD><TD vAlign=center align=middle>15 lb ft
</TD></TR><TR><TD vAlign=center>Charged Air Cooler Clamp
</TD></TR><TR><TD vAlign=center align=left rowSpan=3>Connecting Rod Cap Bolt - Angular Tightening Method
</TD><TD vAlign=center align=middle>1st Step 64 N·m
</TD><TD vAlign=center align=middle>1st Step 47 lb ft
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 30 degrees
</TD><TD vAlign=center align=middle>2nd Step 30 degrees
</TD></TR><TR><TD vAlign=center align=middle>3rd Step 30 degrees
</TD><TD vAlign=center align=middle>3rd Step 30 degrees
</TD></TR><TR><TD vAlign=center>Coolant Pipe Bolt and Nut
</TD></TR><TR><TD vAlign=center align=left>Coolant Tube to Water Pump Nut
</TD></TR><TR><TD vAlign=center align=left>Cooling Fan Pulley
</TD><TD vAlign=center align=middle>41 N·m
</TD><TD vAlign=center align=middle>30 lb ft
</TD></TR><TR><TD vAlign=center rowSpan=2>Crankshaft Balancer Bolt
</TD><TD vAlign=center align=middle>1st Step 100 N·m
</TD><TD vAlign=center align=middle>1st Step 74 lb ft
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 105 degrees
</TD><TD vAlign=center align=middle>2nd Step 105 degrees
</TD></TR><TR><TD vAlign=center align=left rowSpan=3>Crankshaft Bearing Cap Bolt
</TD><TD vAlign=center align=middle>1st Step 98 N·m
</TD><TD vAlign=center align=middle>1st Step 72 lb ft
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 132 N·m
</TD><TD vAlign=center align=middle>2nd Step 97 lb ft
</TD></TR><TR><TD vAlign=center align=left rowSpan=2>Crankshaft Bearing Cap Bolt - Angular Tightening Method
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 90 degrees
</TD><TD vAlign=center align=middle>2nd Step 90 degrees
</TD></TR><TR><TD vAlign=center align=left>Crankshaft Bearing Cap Side Bolt
</TD><TD vAlign=center align=middle>70 N·m
</TD><TD vAlign=center align=middle>52 lb ft
</TD></TR><TR><TD vAlign=center align=left>Crankshaft Position Sensor Bolt
</TD></TR><TR><TD vAlign=center align=left>Crankshaft Position Sensor Spacer Bolt
</TD></TR><TR><TD vAlign=center>Crossmember Bolt
</TD><TD vAlign=center align=middle>100 N·m
</TD><TD vAlign=center align=middle>74 lb ft
</TD></TR><TR><TD vAlign=center align=left rowSpan=4>Cylinder Head M12 Bolt - Angular Tightening Method
</TD><TD vAlign=center align=middle>1st Step 50 N·m
</TD><TD vAlign=center align=middle>1st Step 37 lb ft
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 80 N·m
</TD><TD vAlign=center align=middle>2nd Step 59 lb ft
</TD></TR><TR><TD vAlign=center align=middle colSpan=2>3rd Step 60 degrees
</TD></TR><TR><TD vAlign=center align=middle colSpan=2>4th Step 60 degrees
</TD></TR><TR><TD vAlign=center align=left>Cylinder Head M8 Bolt
</TD></TR><TR><TD vAlign=center align=left>Drive Belt Tensioner Pulley Bolt
</TD></TR><TR><TD vAlign=center>EGR to EGR Cooler Bolt
</TD></TR><TR><TD vAlign=center>EGR Bracket
</TD></TR><TR><TD vAlign=center align=left>EGR Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>EGR Bracket to Cooler Bolt
</TD></TR><TR><TD vAlign=center>Electrical Harness Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Engine Block Coolant Plug
</TD><TD vAlign=center align=middle>18 N·m
</TD><TD vAlign=center align=middle>13 lb ft
</TD></TR><TR><TD vAlign=center align=left>Engine Block Ground Bolt
</TD><TD vAlign=center align=middle>34 N·m
</TD><TD vAlign=center align=middle>25 lb ft
</TD></TR><TR><TD vAlign=center>Engine Mount Through Bolt to Frame
</TD><TD vAlign=center align=middle>75 N·m
</TD><TD vAlign=center align=middle>55 lb ft
</TD></TR><TR><TD vAlign=center>Engine Mount to Block Bolts
</TD><TD vAlign=center align=middle>58 N·m
</TD><TD vAlign=center align=middle>43 lb ft
</TD></TR><TR><TD vAlign=center align=left>Engine Mount to Frame Bolt
</TD><TD vAlign=center align=middle>65 N·m
</TD><TD vAlign=center align=middle>48 lb ft
</TD></TR><TR><TD vAlign=center>Engine Shield Bolt
</TD><TD vAlign=center align=middle>20 N·m
</TD></TR><TR><TD vAlign=center>Exhaust Heat Shield Nut
</TD></TR><TR><TD vAlign=center align=left>Exhaust Manifold Bolt/Nut
</TD><TD vAlign=center align=middle>57 N·m
</TD><TD vAlign=center align=middle>42 lb ft
</TD></TR><TR><TD vAlign=center align=left>Exhaust Manifold Heat Shield Bolts
</TD></TR><TR><TD vAlign=center>Exhaust Outlet Clamp
</TD><TD vAlign=center align=middle>15 N·m
</TD><TD vAlign=center align=middle>11 lb ft
</TD></TR><TR><TD vAlign=center align=left>Exhaust Outlet Heat Shield Bolts
</TD></TR><TR><TD vAlign=center align=left>Exhaust Pipe Bracket Nut
</TD><TD vAlign=center align=middle>53 N·m
</TD><TD vAlign=center align=middle>39 lb ft
</TD></TR><TR><TD vAlign=center>Exhaust Pipe Clamp
</TD></TR><TR><TD vAlign=center align=left>Exhaust Pipe Heat Shield Bolts
</TD></TR><TR><TD vAlign=center>Exhaust Pipe to EGR Cooler Nuts
</TD><TD vAlign=center align=middle>26 N·m
</TD><TD vAlign=center align=middle>19 lb ft
</TD></TR><TR><TD vAlign=center align=left>Fan Pulley Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left rowSpan=3>Flywheel Bolt - Angular Tightening Method
</TD><TD vAlign=center align=middle>1st Step 79 N·m
</TD><TD vAlign=center align=middle>1st Step 58 lb ft
</TD></TR><TR><TD vAlign=center align=middle>2nd Step 60 degrees
</TD><TD vAlign=center align=middle>2nd Step 60 degrees
</TD></TR><TR><TD vAlign=center align=middle>3rd Step 60 degrees
</TD><TD vAlign=center align=middle>3rd Step 60 degrees
</TD></TR><TR><TD vAlign=center align=left>Flywheel Housing Bolt
</TD><TD vAlign=center align=middle>80 N·m
</TD><TD vAlign=center align=middle>60 lb ft
</TD></TR><TR><TD vAlign=center align=left>Flywheel Housing to Upper Oil Pan Bolt
</TD></TR><TR><TD vAlign=center align=left>Front Engine Cover Bolt
</TD></TR><TR><TD vAlign=center align=left>Fuel Filter Bracket Bolt
</TD><TD vAlign=center align=middle>30 N·m
</TD><TD vAlign=center align=middle>22 lb ft
</TD></TR><TR><TD vAlign=center align=left>Fuel Injection Pipe Nut
</TD></TR><TR><TD vAlign=center>Fuel Injector Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Fuel Inlet Pipe Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Fuel Injection Pump Assembly to Cylinder Block Bolt
</TD></TR><TR><TD vAlign=center align=left>Fuel Injection Pump to Bracket Bolt
</TD><TD vAlign=center align=middle>28 N·m
</TD><TD vAlign=center align=middle>20 lb ft
</TD></TR><TR><TD vAlign=center align=left>Fuel Injection Pump Drive Gear Nut
</TD></TR><TR><TD vAlign=center>Fuel Line Bracket Nut
</TD></TR><TR><TD vAlign=center align=left>Fuel Temperature Sensor
</TD></TR><TR><TD vAlign=center>Fuel Pipes Bracket Bolt
</TD></TR><TR><TD vAlign=center>Fuel Pressure Relief Valve
</TD></TR><TR><TD vAlign=center>Fuel Rail Assembly Bolt
</TD></TR><TR><TD vAlign=center>Fuel Rail Balance Pipe Bolt
</TD></TR><TR><TD vAlign=center align=left>Generator Bracket Bolt and Nut
</TD></TR><TR><TD vAlign=center>Generator Positive Cable Nut
</TD></TR><TR><TD vAlign=center align=left>Glow Plug
</TD></TR><TR><TD vAlign=center>Glow Plug Controller Bolt
</TD></TR><TR><TD vAlign=center>Glow Plug Harness Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Glow Plug Nut
</TD><TD vAlign=center align=middle>2 N·m
</TD><TD vAlign=center align=middle>18 lb in
</TD></TR><TR><TD vAlign=center align=left>Glow Plug Power Feed Nut
</TD></TR><TR><TD vAlign=center align=left>Glow Plug Relay Assembly Bolt
</TD></TR><TR><TD vAlign=center>Heater Outlet Pipe Bolt
</TD></TR><TR><TD vAlign=center align=left>Heater Pipe Bolt
</TD></TR><TR><TD vAlign=center>Hood Hinge Bolt
</TD></TR><TR><TD vAlign=center align=left>Idle Pulley Bolt
</TD></TR><TR><TD vAlign=center align=left>Injector Bracket Bolt
</TD><TD vAlign=center align=middle>23 N·m
</TD></TR><TR><TD vAlign=center align=left>Intake Manifold Bolts/Nuts
</TD></TR><TR><TD vAlign=center align=left>Oil Cooler Adapter Bolts
</TD></TR><TR><TD vAlign=center align=left>Oil Cooler Adapter Nuts
</TD></TR><TR><TD vAlign=center align=left>Oil Cooler Assembly Bolts
</TD></TR><TR><TD vAlign=center align=left>Oil Cooler Adapter Stud
</TD></TR><TR><TD vAlign=center align=left>Oil Drain Plug
</TD><TD vAlign=center align=middle>84 N·m
</TD><TD vAlign=center align=middle>62 lb ft
</TD></TR><TR><TD vAlign=center align=left>Oil Fill Tube Bolt
</TD></TR><TR><TD vAlign=center align=left>Oil Filter
</TD><TD vAlign=center align=middle>24 N·m
</TD></TR><TR><TD vAlign=center align=left>Oil Gallery Plugs
</TD></TR><TR><TD vAlign=center align=left>Oil Level Indicator Tube Bolt
</TD></TR><TR><TD vAlign=center align=left>Oil Level Sensor Bolt
</TD></TR><TR><TD vAlign=center>Oil Level Sensor Harness Bolt
</TD><TD vAlign=center align=middle>40 N·m
</TD><TD vAlign=center align=middle>29 lb ft
</TD></TR><TR><TD vAlign=center align=left>Oil Pan Bolts/Nuts - Lower
</TD></TR><TR><TD vAlign=center align=left>Oil Pan Bolt - Upper
</TD></TR><TR><TD vAlign=center>Oil Pan Skid Plate Bolt
</TD></TR><TR><TD vAlign=center align=left>Oil Pressure Sensor Unit
</TD><TD vAlign=center align=middle>49 N·m
</TD><TD vAlign=center align=middle>36 lb ft
</TD></TR><TR><TD vAlign=center align=left>Oil Pressure Relief Valve
</TD><TD vAlign=center align=middle>39 N·m
</TD></TR><TR><TD vAlign=center align=left>Oil Pump Bolt
</TD></TR><TR><TD vAlign=center align=left>Oil Pump Driven Gear Nut
</TD></TR><TR><TD vAlign=center align=left>Oil Pump Gear Cover Bolt
</TD></TR><TR><TD vAlign=center align=left>Oil Pump Pipe and Screen Assembly Bolts and Nuts
</TD></TR><TR><TD vAlign=center align=left>Piston Cooling Nozzle Eye Bolt
</TD></TR><TR><TD vAlign=center>Positive Cable Junction Block Bracket to Power Steering Pump Bolt
</TD></TR><TR><TD vAlign=center align=left>Positive Crankcase Ventilation Cover Screws
</TD><TD vAlign=center align=middle>4 N·m
</TD><TD vAlign=center align=middle>35 lb in
</TD></TR><TR><TD vAlign=center>Positive Crankcase Ventilation Oil Separator Bracket Nut
</TD></TR><TR><TD vAlign=center>Power Steering Pump Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Power Steering Pump Bolt
</TD></TR><TR><TD vAlign=center align=left>Rocker Arm Shaft Bracket Bolt
</TD></TR><TR><TD vAlign=center align=left>Starter Motor Bolt
</TD><TD vAlign=center align=middle>78 N·m
</TD><TD vAlign=center align=middle>58 lb ft
</TD></TR><TR><TD vAlign=center>Transmission Fill Tube Nut
</TD></TR><TR><TD vAlign=center align=left>Thermostat Housing Bolts/Nuts
</TD></TR><TR><TD vAlign=center align=left>Thermostat Cover Bolt
</TD></TR><TR><TD vAlign=center>Torque Converter Bolt
</TD><TD vAlign=center align=middle>60 N·m
</TD><TD vAlign=center align=middle>44 lb ft
</TD></TR><TR><TD vAlign=center>Transmission Oil Cooler Clip Nut
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Bolt
</TD><TD vAlign=center align=middle>108 N·m
</TD><TD vAlign=center align=middle>80 lb ft
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Coolant Outlet Pipe Bracket Nut
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Heat Shield Bolts
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Oil Return Pipe Stud
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Oil Supply Hose Eye Bolt
</TD></TR><TR><TD vAlign=center align=left>Turbocharger Oil Return Pipe Bolts/Nuts
</TD></TR><TR><TD vAlign=center align=left>Upper Oil Pan to Flywheel Housing Bolts
</TD></TR><TR><TD vAlign=center align=left>Valve Adjusting Nut
</TD></TR><TR><TD vAlign=center align=left>Valve Lifter Holdown Bracket Bolt
</TD><TD vAlign=center align=middle>11 N·m
</TD><TD vAlign=center align=middle>97 lb in
</TD></TR><TR><TD vAlign=center align=left>Valve Rocker Arm Cover Bolt - Lower
</TD></TR><TR><TD vAlign=center align=left>Valve Rocker Arm Cover Bolt - Upper
</TD><TD vAlign=center align=middle>8 N·m (Two Times)
</TD><TD vAlign=center align=middle>71 lb in (Two Times)
</TD></TR><TR><TD vAlign=center align=left>Water Outlet Bolts
</TD></TR><TR><TD vAlign=center align=left>Water Pump Bolt
</TD></TR><TR><TD vAlign=center>Water Pump Inlet Pipe Bolts
</TD></TR></TBODY></TABLE>
© 2008 General Motors Corporation. All rights reserved.
http://www.thedieselgarage.com/forums/showthread.php?t=669
