Printable View (47 KB)
TSB
07-2-7 6.0L - REDUCED ENGINE PERFORMANCE - HIGH ALTITUDE
Publication Date: January 22, 2007
FORD: 2005-2007 F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty vehicles equipped with a 6.0L diesel engine may exhibit reduced engine performance condition with no diagnostic trouble codes (DTCs) when operated above 5,000 feet above sea level. This condition may affect 2005-2006 vehicles built before 3/15/2006 that had a powertrain control module (PCM) recalibration, and 2006-2007 vehicles built 3/15/2006 or later.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release IDS 47.3 and higher. This new calibration is not included in the 2007.1 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
070207A 2005-2007 F-Super Duty 6.0L: Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module (Do Not Use With 12650D, 12650D84) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
recalem 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
