Printable View (47 KB)
TSB
07-8-4 DIESEL ENGINE - OVERHEATING WITH A SNOW PLOW INSTALLED ON VEHICLES WITHOUT THE FACTORY INSTALLED SNOW PLOW PACKAGE
Publication Date: April 11, 2007
FORD: 2005-2008 F-Super Duty
This article supersedes TSB 06-24-12 to update the vehicle model years and engines.
ISSUE:
Some 2005-2008 F-Super Duty vehicles with a diesel engine, that are not equipped with the factory snow plow package, may exhibit an engine overheat condition if a snow plow is installed on the vehicle. The condition typically will occur during normal highway driving. This is due to the snow plow blade disrupting airflow to the engine, causing the cooling fan to stop turning or to spin in reverse.
ACTION:
A new clutch fan (only for snow plow applications) may be installed to correct the condition. Cost of the new clutch fan and its installation is the responsibility of the customer. Refer to Workshop Manual Section 303-03 for removal and installation.
PART NUMBER PART NAME
4C3Z-8A616-SA 6.0L Fan Clutch
8C3Z-8A616-A 6.4L Fan Clutch
WARRANTY STATUS:
Information Only - Not Warrantable
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
