Printable View (47 KB)
TSB
07-9-1 2008 F-SUPER DUTY- LIGHTING ON SNOW PLOW EQUIPPED VEHICLES - BUILT BEFORE 04/18/2007
Publication Date: April 19, 2007
FORD: 2008 F-Super Duty
ISSUE:
2008 F-Super Duty vehicles are equipped with a smart junction box (SJB) and it's function is to provide protection against excessive current loads, typical of a short circuit, by shutting down circuit operation. The SJB strategy may interpret the switching between Ford headlamps and aftermarket snowplow headlamps, and vice-versa, as a short-to-ground, causing the power feeding a headlamp circuit through the SJB to be turned off.
ACTION:
Reprogram the SJB to the latest calibration using IDS release 48.9 patch 9 and higher or 49.1 patch 1 and higher. This new calibration is not included in the VCM 2007.5 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
070901A 2008 Super Duty: Reprogram The SJB (Do Not Use With 12650D, 12651D, 12651D4) 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
15604 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
