here are some cummins parts for sale
89-93 12v cummins grid heater solenoids with wireing $50
94-98 12v cumimns grid heater solenoids with wireing $50
89-98 12v cummins stock valve springs $75
89-93 12v cumimns ve stock fuel pin or can be custom gound for more fuel if needed stock $50 ground $75
89-93 12v cummins ve stock gov. spring $10
89-02 cummins clutch fan $75
98.5-02 24v cummins upper intake plate $20
contact me at [email protected]
01 dodge quad cab 5spd 280000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, industrial injection dragon fire pump, .093 connector tubes, .093 lines, ats head studs, 300 hp injectors 7x16 , s400 turbo and s300 twins, custom billet intake plate, cooling mist water meth injection, valair twin disc clutch 3850lb, 1 3/8 input shaft, south bend upgrade hydulics, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valair on board air with Siberian express train horns,
Pulling stats.
Hanks 4x4 3rd 282.56ft
01 dodge reg cab 5spd 279000 miles cold air intake afe, cooler tubz, single electric fan or I can put the stock clutch fan on, air dog 150 new 1 month old, stainless steal nerf bars, edge juice att. hot unlock, .093 connector tubes, valair single disc clutch, 4inch from turbo to duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers for sale
84 Chevy k30 reg cab with 94 12v p pump Cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, RQV gov., 370 injectors that are extrude honed bigger, o- ringed and head stud, milled off intake, sbc valve springs titanium keepers and retainers, portand polish head, marine lift pump, custom ground cam, cooling mist water meth. injection, valair twin disc clutch 3850lb, 1 3/8 input shaft, valair hydulic upgrade, industrial injection silver bullet 66 turbo, no fuel plate, .093 polish stainless steel fuel lines, aluminum radiator, single 5 inch miter cut stack
Pulling stats
Hanks 4x4 7th 256ft
03 Honda Rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted 170 main, spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 Yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 12.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod, full skid plates, heavy duty racing clutch, jetted
07 Kawasaki klx250 on off road bike moose air filter, fmf pipe mostly stock
Member stats
diesel bombers
the diesel garage
Cummins forum
competition diesel
nyrok’s
atv connection
