12v time!!!
18066 Views 167 Replies 25 Participants Last post by  stacks
just picked it up today, has blown egr cooler and possible hgs.....
121 - 140 of 168 Posts
pics coming later today
geez, hurry up already. do a write up too so i can print it.
x2:thumbsup
ill get ya guys a write up this week when im bored sittin in the hotel....got pics just need to load them...
Reactions: 1
things that i wana change is better ic pipes, ic and boots/clamps, the upper and lower rad hoses, need a new dip stick, paint or polished valve covers, new exhuast manifold, compounds, and a little more fuel.....right now its not as clean and shiny as id like it but i wana get everything fitted right before i make the final pieces.....aand yes i do have an air filter for it but had it off in the pic cause i was cleaning it
Reactions: 3
Very nice:thumbsup. Well come to the dark side.:haha
wow, never noticed how small the 12v was, gets the job done though. I can't wait till it comes time for mine.
Looks like it was meant to be there. Chris
Jason i have billet valve cover for you if you need one. Give me a call.
Dan
NIce job..... ! how much money was involved.? I wouldnt mind me doing that if Ican find me a doner truck... hell I got everythingI need.... just need a truck
Very nice. I know you'll enjoy it for sure now!
well i bought 2 trucks and all the parts for around 15k, hopefully get some money back selling all the spare parts....hopefully end up around 12k in the end....
this is how the project went...
got the 97 dodge from dan, traded my 2006 in for the 2005 with the blown engine. i stripped the 05 of all the 6.0 crap, trans, wiring...ect ect.. and hot water pressure washed the engine bay. took the engine outa the dodge and then started figuring things out...
to convert the auto to a manual i needed clutch and brake pedal from another sd that was 50$$, slave/master assembly 140$...shifter assembly with boot was 250ish$, removed the auto lever....cut hole in floor, make diff crossmember and moved it into the second set of holes in the frame, the manual trans is 2 3/4 longer than the auto, rear driveshaft shortend and front was long enough....trans and clutch from dan(sogrand)
to mount cummins i got the common rail style engine mounts from destoked they were 400ish overnighted, adaptor for 6.0 zf6 745$...the engine sits about two inchs to the right from center but the fan ends up being centered.....it leans back about 5-6degrees....i used the dodge accessories...had the line from the pump to the hydroboost made and the other two didnt neeed to be changed...the ac isnt done yet but just needs the ford ends crimped on the dodge lines....for the turbo i had to flip the cummins manifold and make a 1/4in spacer so i could clock the turbo the way i wanted and made a new oil feed line and drain line, also made a 4in down pipe.....for the ic pipes the straight dodge one worked just needed to be shortend and then had to make one for the driverside, made lower rad hose and shortend the upper....for wiring i gutted the ford harness of everything but the a/c wires,crank sensor, ect, oil psi, alt, and the tcase wires..... reloomed everything and got some adaptors from the hardware store for the ford sensors in the cummins block....for fuel i used a fass pump and regulated it on the return side of the pump....also had to T the return from the injectors into the main return line....ummmm for the coolant i ran a line from the ford degas bottle to one of the heater core ports, and the other from the heater core to the other port....the starter is on a push botton and fuel pump and shut off are on switches, key only needs to be on to unlock steering wheel and turn guages, radio, and accesssories on.......batterys stayed in stock location, got an airfilter that mounts right to the turbo.....ran some trans lines from trans to rad.....umm i think thats about it.......
Reactions: 3
aww crap for the alt to make it regulate i used an old school external ford regulator...and getting the destroked crank sensor kit for the tach
i have a perfect truck for it!
how kind..! you gonig to give me you SD?:haha
looks good
no, i was thinking you give me your motor. :D ok, sell it. wait, it has an auto. no thanks.
YEah a FULLY BUILT auto........:haha from gorend..!
Looks great.
true, id get rid of it for an nv4500 and a dual disc.
i got a video for you guys, hopefully get it loaded tomorrow night forgot camera in shop
