· Chitowns Biggest Baller
90 chevy c3500 dually 100% rust free the body just came up here from California!! its custom painted mustang grabber blue. with a 5.9 cummins swap! here is the list of mods this trucks gets 25MPG!!lowered with mini a c notched frame*1998 nv4500 5 speed trans*brand new valair clutch with throw out bearing and pilot bearing*frito lay power steering and hydroboost*custom drive shaft*3.42 gears in the 14 bolt rearend*gaTennessee diesel conversions slave cylinder kit with steel braided line*auto world cummins conversion motor mounts*AIR DOG 150 FUEL PUMP*5'' stacks*custom aluminum radiator*flex a lite electric fan*with autometer speedo, fuel gauge,boost gauge, coolant temp and LSSPRO tach and fuel pressure*black 16'' Alcoa wheels*roll pan with a hideen hitch*the tail gate handle has been shaved and moved to the in side for a cleaner look!*bed liner*optima battery*tubular upper control arms with drop spindle*I am sure I am forgetting a bunch call for more info 847-401-1714 I can txt you pics or if any one can post pics for me txt me and I will txt you pics to post! 847-401-1714*asking $9500 obo
