My name is Nick and I have the truck listed above. The parking lights don't come on and neither do the gauge lights. Any suggestions.
check all fuses, cannot remember if they are on the same circuit. check burnt headlight switch and burnt ignition switch connections. also, u may have 2 different problems here.
The circuit diagram I have is for a 98 4700 and it shows fuse f-8 powers pin 30 of the tail light relay and fuse f-24 powers wire 50a pin5 of the headlight switch. With the headlight switch turned on you should have power on wire 58a at the switch which feeds the taillight relay on pin 86.
