Are you able to pull any codes from the ecm? Is the ecm getting battery and ignition voltage? High oil pressure pump could have failed. If I remember right if you unplug the 2 pin connector from the solenoid on the pump it will send all the oil pressure it can to the injectors. I've seen timing sensor failures and tone ring failures. Also too much camshaft endplay lets the tone ring move too far away from the sensor. These are just some things that come to mind
