My check engine light came on I read the code is said p0430 ( Catalyst system Efficiency below Threshold Bank 2) the truck has two catalytic converters is there a way to pin point just what the problem is. I am not convinced that the cat on bank 2 is bad.
A little late but I took your code P0430 with that phrase included and it seems to point to a cat not working accordingly, but, since you believe its not you need to monitor other things involved and test as well.
Reactions: RachelJeanWalker
As it turned out I did replace both cats and it still wouldn't pass emission test but did run so much better. I replaced the gas cap and all is good in Chevy world
Good deal, just keep up maintenance and it will always run fine. Did they say what reading(s) was too high if you remember?
