I’m working on a 1999 MT45 with a 5.9l cummins 24v Alison transmission.
I am not getting a response on the throttle !
Any idea what could be causing this ?
Engine number is 56552519 if needed.
Thanks
Had a tech scan it and it’s gettjng Voltage/ response from the peddle to the ecm, now we going to go thru the wiring from the pump to the ecm
What was the letter in front of the code?
That's either a throttle position sensor or a Transmission ECU to ECM Communication Lost .
If it's intermittent check the connections.
If the truck is constantly dead pedsl, it sounds like the calibration file needs to be reloaded by someone with Insite.
