What size of tires can you get under the LMM with a 2" level? If someone has some pictures that would be great.
The most common package of parts to use when using the Cognito UCA's is adding the Cognito steering braces and front and rear Bilstein shocks that are the correct ones to be used with the Cognito UCA.I am looking at a Cognito A arms kit with 285s has anybody went this way and what other parts do you need to do this. Thanks
Stumpy 442
I don't know what to tell you except the dam things rub when it was stock now it does not. You know there is a little difference in a 03 GMC 1500....stock an a 2007.5 LTZ Duramax285s should fit stock....I have 285s on my 03 gmc 1500....stock. 305s will fit with the bars cranked, might but the bumper lip, just trim whatever rubs with a die grinder...if nessecary
