P0102 MAF or VAF CKT Low Input and P0332 Knock Sensor 2 Low Input. after i fixed everything with the O2 sensors on friday, these 2 popped up yesterday. checked all the fuses and everything was good. checked the MAF plug and it seems fine. not sure where the knock sensor is or what to check for them now.
Gone Fishin...
Okay. I get it now. I had a friend who went through this same serious of events with his 03'. Turns out the MAF, 02 sensors, and knock sensors he replaced where not the cause of the problems. He had a small vaccuum leak that was adding unmetered amounts of air into the engine.
negative. O2 sensors were the fuse. MAF was the plug, bad connection. knock sensors and plugs were filled with water. pulled intake, change knock sensors since i got them for free, cleaned all the plugs, put it together, and its good. at least for 2 years.
