Howdy all! Does any one add a little 2 stroke oil to your fuel? I have always heard that it is good. I might need to start doing this if so.:goodvsevil
I do add 2 stroke oil but I am also running jet fuel.
TDG Official Poo Flinger
It's benefits the Ford 6.0L's,...haven't heard of any real benefits for the Chevy's yet...
Do you run JP-5, 8, or 4? How does it do far as fuel mileage close to the same as #2 diesel?
CRAZY CANUCK
In the HPCR engines im not entirely convinced that you need it, nor will you see any benefits.... these fuel systems were designed to run on USLD..... im not saying it will hurt but im not sure that your gaining anything... i tried it in my 05 dodge and saw no improvement in how smooth or quitetly it ran, nor any improvement in MPG's
However if your interested in it for sure PM Moparman73... hes a mod and a 2cycle guru
I run Jet-a. It's a commercial type of jet fuel not military. Mileage and power are lost but not too bad.
TDG Mafia # 81
It does help in the Duramax also, many use it. Helps to clear up a rough idle if the FPR is just starting to fail and has been known to increase economy also.
I add a quart once a month to my truck and it helped take care of the FPR on mine.
Tony
it also helps with the gel issue of the fuel too. read up on moparmans site he has all you need to know about it
