just a bit of info, i installed a set of 2000 dodge factory mags on my 1992, the rim offset is different and the front rims hit the tie rod ends and sets the tire in an extra 3". i bought 4, 1 1/2" wheel spacers w/ lugs and it sets the outside of the tires exactly where the steel rims had them, the inside, due to wider rims and bigger tires is 1 1/2" further in..the wheel spacers had bigger studs allowing me to use the stock lug nuts off the 2000 and use the stock hub caps off the 2000, a 4" hole saw was perfect to remove the center of the front hub caps to clear the locking hubs... looks like a factory job.
JakeBrakeIH
:nopics
I would love to see what this looks like all done...do you have any pics on how you did it???:popcorn:
