We bought this truck recently to use as a secondary truck for hauling loads, but now we decided to get ourselves a larger truck so we're gonna just use our new one as secondary. We haven't even driven the truck much yet since we've bought it since we don't need it anymore and basically all we've done is fix a few things. We just replaced the dash with a new one, not just the cover, replaced front end ball joints, pitman arm, idler arm, and new tires, it drives really well now! The previous owner said he just replaced the motor, injectors, injector pump, and lift pump a few thousand miles ago, now with 100 hp injectors, an aftermarket injector pump, and a holly lift pump. Also has a Valair 550 hp clutch. The truck has loads of power and drives great! Turbo pushes 35 psi easy and doesnt have a programmer or chip on it that I know of. The towing package is also all ready to go!
Now for the bad, the clear coat is coming off on the front left fender, the bed is quite messed up, broken cross member in the bed or something, which we can try to fix before sale (or we can build you a new flat bed for a good deal), crusie control doesn't work, oil pressure gauge doesn't work, and some interior stuff isn't perfect anymore which I guess is normal on these trucks... The doors still close great and the body looks to still be aligned well which I think is a good sign. We also have new factory tail light covers to put on the rear since these are so dark you can hardly see the light during the day!
The truck has 130K miles, located in Maxey, TX, and the price is $9,500 OBO. We bought it for $11,000 before all the repairs we have done on it (about 2-3 grand!) and only put like 1-2K miles on it yet..
Here's some pics, if you want more detailed ones of anything just let me know!
gotta love black smoke!
We just fixed the bed a bit and it's better than it was, the sides are just not very sturdy, but it's alright besides that. Her'es a pic
How big are you wanting to go ever consider a trade for
http://www.thedieselgarage.com/forums/showthread.php?t=101580
Also I assume this is a 2wd...
Can you post a picture of where the bed is messed up?
Yes it is a 2wd. And the gauges are already taken out and I somewhat cleaned out the inside a little since the pictures.
We were going to get a semi but I think we're first going to put a few more miles on our current 3500 so we work the $$$ off a bit better and not loose so much. We just need the money more right now than the vehicle..
Ah gotcha
Bump for $9,000! Also, if anybody would be interested, I could make you a killer deal on a new trailer of your choice to go along with the truck...
