no nthey will rub, but with a 2.5" leveling kit and f-350 rear blocks they will fit fine, you could also use 5" rear blocks from readylift. thats what i did to mine, gives it a little bit of rake to the front so it levels out when loaded
Mod Friendly Title
Not recommended on that skinny of a rim...
thanks for advise. My friend has 315/75/16 on his stock F250 and the y fit fine but dont know if they scrub or not
Mod Friendly Title
They shouldn't rub, but he's going to wear out the center of those tires FAST
The one and only
A 315/75/16 will rub on a stock F250. Unless you trim the front.
I am running them with a 2.5" leveling kit and a 3" block and they still almost rub the front bumper because i have not trimmed it.
Also i would not run them on a stock wheel because the side walls will be really week and could roll.
Reactions: martin0371
We've got a 4" lift on our excursion and the air dam had to be trimmed.
i run 305/70/16 mastercraft courser cts on my stock rims. i do have a leveling kit on it though. however, they greatly improve the overall stance of the truck. I have 50,000 miles on them so far, and i plan to get another 5-10,000. they are starting to cup on the edges.
