Will edge comp work good with the HO motor? Also this box doesnt come with the outlook monitor, correct? This truck has a 6 speed manual btw
Thanks for help..
Matt
Ghost
Thanks for help..
Matt
Yes and Correct.
The comp still will work with the HO motor, but you won't see the power gain you see with SO Motor. You will still be pleased with the results. All the High Outputs from 01-02 have the 6 Speeds too and you are going to want to look into buying a clutch for it down the road, that being the only weak spot in the drivetrain.
Well thanks Phily..
I will think about the clutch later on, but this is mainly going to be my mildly modded work truck, you know like airdog, edge, straight pipe, bhaf. thats about it til i need a clutch.
Thanks for the info
Matt
Local Cummins nut
Also highly recomend getting a good Lift pump like a FASS or AirDog so you dont starve the VP44 & burn it up
Reactions: Superstroker
