I could use a Oasis report on this pick up. Its a 4X4 F-250 superduty quad-cab....80K miles, VIN: 1ftnw21f42eb88790 . Thanks for the help.:Thumbup: By the way they're asking 23,990.
OASIS RESULT:
1FTNW21F42EB88790
See bottom of the OASIS result for contact ID
02/08/2006
18:08:34
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/16/2002 BUILD DATE
01/16/2002 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTNW21F42EB88790
1FTNW21F42EB88790 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 16-JAN-2002 16-MAR-2002 144067 USA 17 5B03 050301 F81Z 3222 FA P82 33 35381
AWS Claim Key: 6950235 Trx Code: E84 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 02175 - * Name: PALLOTTA FORD LINCOLN MERCURY Ph: 330-3456600 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2003 Doc #:113552A
Cust Comments: CUST STATES 4X4 INOP
Tech Comments: 35385 DIAGNOSE,FRONT PINION LOOSE.TRY TO REMOVE YOKE.FROZEN.TRYED PULLERS AND BROKE YOKE. NECESSARY TO TORCH OFF YOKE.RR AND OH FRONT DIFF.NECESSARY TO TORCH OUT PINION AND BRGS. REPLACE RING AND PINION.RESET UP DEPTH. RESEAL BOTH HUBS AND LOCKOUTS.REPLACE INNER AXLE SEALS INSIDE DIFF HOUSING.RETEST. ROADTEST.
1FTNW21F42EB88790 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 16-JAN-2002 16-MAR-2002 144067 USA 17 5V01 0603XX * 1102 * N27 13 35381
AWS Claim Key: 6950236 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02175 - * Name: PALLOTTA FORD LINCOLN MERCURY Ph: 330-3456600 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2003 Doc #:113552B
Cust Comments: TEST DRIVE FOR BRAKE VIBRATION
Tech Comments: 35385 DIAGNOSE,CHECK RUNOUT.MACHINE BOTH FRONT ROTORS ON VEHICLE.LEFT FRONT BEFORE,38.2MM. AFTER 37.2.RIGHT FRONT BEFORE,37.8MM.AFTER 36.8.ROADTEST.
1FTNW21F42EB88790 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 16-JAN-2002 16-MAR-2002 144067 USA 18 5A11 050201 B6D 4616 A K02 42 35391
AWS Claim Key: 7252492 Trx Code: E90 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 02175 - * Name: PALLOTTA FORD LINCOLN MERCURY Ph: 330-3456600 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2003 Doc #:114319A
Cust Comments: CHECK NOISE FRONT
Tech Comments: 35394 DIAGNOSE,NEEDS FRONT PINION BRGS.RR AND OH FRONT DIFF.REPLACE RING AND PINION AND BRGS. RESET UP DEPTH.NECESSARY TO TORCH OUT PINION AND BRGS.RECHECK.ROADTEST.
