Have a 2004 5.9 Cummins in a motorhome that is showing intermitten EGR code 411 any ideas what to look for ? Thanks for any ideas.
:readHere is information on the code. Fault code is 2273.
CODE REASON EFFECT
Fault Code: 2273
PID: P411
SPN: 411
FMI: 3/3
LAMP: Amber
SRT:
EGR valve differential pressure sensor circuit - shorted high. High voltage detected on the EGR differential pressure sensor circuit.
EGR valve will be closed.
Circuit Description
The exhaust gas recircultion (EGR) differential pressure sensor has two ports that sense a pressure drop across the EGR gas entrance to the intake connection. The electronic control module (ECM) uses this pressure drop to calculate the amount of EGR gas entering the intake. This calculation helps to determine the commanded position of the EGR valve (and VG turbocharger) that will control the amount of EGR gas flow into the engine.
Component Location
The EGR differential pressure sensor is mounted on the side of the intake air horn. Refer to 100-002 for a detailed component location view.
NOTE: The sensor is connected to the engine harness through a short pigtail harness. The pigtail harness is permanently affixed to the sensor. Do not try to remove the connector that is attached to the sensor body or damage to the sensor will occur.
Shop Talk
The EGR differential pressure sensor shares supply and return wires in the engine harness with other sensors. Open circuits and short circuits in the engine harness can cause multiple fault codes to be active. Before troubleshooting Fault Code 2273, check for multiple faults. Possible causes of this fault code include:
* Open return in the harness, connectors, or sensor
* Signal circuit shorted to sensor supply or battery voltage
* Supply circuit shorted to battery voltage.
Guided Step 1 - Check the fault codes.
Guided Step 1A - Check for multiple fault codes.
Conditions
* Connect the INSITETM electronic service tool.
* Turn keyswitch ON.
Action
* Start the engine and let it idle for one minute.
* Use INSITETM electronic service tool, read the fault codes.
Fault Code 227 active?
YES NO
Troubleshoot Fault Code 227.
No Repair
Fault Code 227
Go to 1B
Guided Step 1B - Read the fault codes.
Conditions
Action
Fault Code 2273 active?
YES NO
No Repair No Repair
Go to 2A
Inactive or Intermittent Fault Code, Procedure 019-362
Guided Step 2 - Check the EGR differential pressure sensor and circuit.
Guided Step 2A - Inspect the engine harness and sensor connector pins.
Conditions
* Turn keyswitch OFF.
* Disconnect the EGR differential pressure sensor from the engine harness.
Action
Inspect the engine harness and EGR differential pressure sensor connector pins for the following:
* Corroded pins
* Bent or broken pins
* Pushed back or expanded pins
* Moisture in or on the connector
* Missing or damaged connector seals
* Dirt or debris in or on the connector pins.
For general inspection techniques, refer to Component Connector and Pin Inspection, Procedure 019-361.
Dirty or damaged pins?
YES NO
Clean the connector and pins.
Repair the damaged harness, connectors, or pins if possible.
Refer to the Resistance Measurements Using a Multimeter and Wiring Diagram, Procedure 019-360.
No Repair
Go to 4A
Go to 2B
Guided Step 2B - Check the circuit response.
Conditions
* Connect INSITETM electronic service tool.
Action
Check for the appropriate ECM response after 30 seconds.
* Use INSITETM electronic service tool to read the fault codes.
Fault Code 2273 inactive and Fault Code 2274 active?
YES NO
No Repair No Repair
Go to 2C
Go to 3A
Guided Step 2C - Check the EGR differential pressure sensor supply and return circuit at the harness.
Conditions
Action
* Measure the voltage between the EGR differential pressure +5 volt supply pin and the EGR differential pressure return pin at the sensor connector of the engine harness.
4.75 to 5.25 VDC?
4.75 to 5.25 VDC?
YES NO
Replace the EGR differential pressure sensor.
Refer to Procedure 019-370.
No Repair
Go to 4A
Go to 2D
Guided Step 2D - Check the EGR differential pressure sensor supply and return circuit at the ECM.
Conditions
* Disconnect the engine harness from the ECM.
Action
* Measure the voltage between the EGR DIFFERENTIAL PRESSURE +5 VOLT SUPPLY pin and the EGR DIFFERENTIAL PRESSURE RETURN pin at the ECM port.
SMALL | MEDIUM | LARGE
4.75 to 5.25 VDC?
4.75 to 5.25 VDC?
YES NO
Repair or replace the engine harness.
Replace the ECM.
Call for authorization. Refer to Procedure 019-031.
Go to 4A
Guided Step 3 - Check the ECM.
Guided Step 3A - Inspect the engine harness and ECM connector pins.
Conditions
Action
Inspect the engine harness and ECM connector pins for the following:
* Corroded pins
YES NO
Clean the connectors and pins.
No Repair
Go to 4A
Go to 3B
Guided Step 3B - Check the ECM response.
Conditions
Action
Check for the appropriate ECM response.
YES NO
Replace the ECM.
Go to 4A
Guided Step 4 - Clear the fault codes.
Guided Step 4A - Disable the fault code.
Conditions
* Connect all components.
Action
* Verify that Fault Code 2273 is inactive.
Fault Code 2273 inactive?
YES NO
No Repair No Repair:read
more questions on the 5.9 EGR Problem
I am using a silver leaf vmc to read my codes. and since the problem is an intermitten problem someone had told me it could just be the sensor and would that be a simple change out?
