ok here is the rest of it...lots
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 2E02 030408 3C3Z 9N693 JA L65 D8 7493
AWS Claim Key: 3870383 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212001
Cust Comments: CUSTOMER STATES HAS OIL LEAK DIAG AND FIX LAST OIL CHANGE 2000 MILES AGO
Tech Comments: CHECKED OUT ADDED DYE TO ENGINE OIL AND BLACKLIGHT TESTED FOUND LEAK FROM CAM POS SENSOR ORINGS REPLACED ORINGS AND
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 2H02 030008 3C3Z 6F089 AA D42 42 7493
AWS Claim Key: 3896935 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212002
Cust Comments: CUSTOMER STATES SEEMS TO SURGE AT 75 80MPH
Tech Comments: CHECKED OUT RAN 6.0 PERFORMANCE DIAG FOUND STICKING VGT SOLE REPLACED VGT AND UPDATED PCM TO LATEST CALIBRATION ALL OK.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 6 3A03 * * * * * * 7493
AWS Claim Key: 3870382 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:56212003
Cust Comments: CUSTOMER HAS RECALL # 04B24 REVERSE PLANET GEAR
Tech Comments: 1 PERFORM RECALL ONLY KIT 1 WAS NEEDED.OPER 04B24N 6.4 HRS.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 7 2G04 031401 * 12A650 * D42 04 9160
AWS Claim Key: 4512583 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2005 Doc #:56369901
Cust Comments: CUSTOEMR STATES LACK OF POWER DIAG AND FIX
Tech Comments: WARRANTY, RAN PERFORMANCE DIAG NO CODES I PERFORMED AN REPROGRAM ON THE PCM, TCM, AND FICM RE TESTED OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 1G04 030008 5C3Z 8509 A N11 30 13443
AWS Claim Key: 6022883 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758101
Cust Comments: CST STATES THERE IS A NOISE COMING FROM THE ENGINE AREA WHILE RUNNING.
Tech Comments: PERFORMED TSB 05 13 16 051316A 1.3
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 2E02 030408 3C3Z 9N693 HA L65 D1 13443
AWS Claim Key: 6022882 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758102
Cust Comments: CST STATES THERE OIL LEAK COMING FROM THE ENGINE PASS SIDE.
Tech Comments: ADDED DYE TO ENGINE OIL AND BLACKLIGHT TESTED FOUND OIL LEAK FROM CAM SENSOR ORINGS AND FROM LOW PRESSURE OIL PUMP REG. CAP ORING REPLACED ORINGS TEST DROVE ALL OK.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 10 * * * * * * * 13443
AWS Claim Key: 6022881 Trx Code: 05S34 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758103
Cust Comments: CST REQUEST TO HAVE THE RECALL 05 S 34 COMPLETED.
Tech Comments: COMPLETED RECALL 05S34E 1.2 05S34G 0.3 W 2 DAYS RECALL RENTAL $100.00
AWS Claim Key: 6022880 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:56758104
Cust Comments: PERFORM RECALL 59B01
Tech Comments: 1 TEST DRIVE AFTER RECALLS PERFORMED
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 13 * * * * * * * 16674
AWS Claim Key: 6865277 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:57135102
Cust Comments: CUSTOMER HAS RECALL # 59B01 TEST DRIVE
Tech Comments: 1 PERFORMED TEST DRIVE AS PER RECALL 59B01A.
AWS Claim Key: 6865278 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-SEP-2005 Doc #:57135101
Cust Comments: CUSTOMER HAS RECALL # 05E15 EXHAUST BACK PRESSURE SENSOR
Tech Comments: 1 REPLACED EBP SENSOR AND CONNECTOR. REPROGRAMMED PCM AS PER RECALL 05E15G.
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 17 1H03 030008 * 9F452 * D36 42 22080
AWS Claim Key: 8339097 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2006 Doc #:57789901
Cust Comments: CUSTOMER STATES WHILE DRIVING TRUCK WAS SURGING AND SEEM TO BLOW BLACK SMOKE, ALSO RUNS ROUGH DIAG AND FIX
Tech Comments: CHECKED OUT RAN 6.0L PERFORMANCE GUIDE SHEET DIAG WITH TEST DRIVE FOR INTERMITANT DIAG PERFORMED PINPOINT TESTS W9 W13 FOUND STICKING EGR VALVE REPLACED EGR VALVE AND CLEANED EGR PASSAGEWAYS REPEATED ALL OPERATION CODES AND TIMES AS FOLLOWS 6005F 0.4 6005F13 0.2 6005F1 0.1 6005F2 0.1
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 19 1G03 030507 * 8620 * N11 33 24372
AWS Claim Key: 8884933 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:58104101
Cust Comments: CUSTOMER STATES THAT THERE IS A REALLY BAD SQUEAKING NOISE COMING FROM THE BELT SYSTEM, DIAGNOSE AND ADVISE
Tech Comments: WARRATNY,DEGLAZED THE BELT AND INSTALLED DRESSIG RE TSTED OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 24 1H03 030804 4C3Z 9J460 A D42 42 31217
AWS Claim Key: 10193615 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 09940 - * Name: LEGACY FORD LINCOLN MERCURY Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2006 Doc #:58768501
Cust Comments: CUSTOMER STATES; VEHICLE DIES AND RUNS POORLY ROUGH HAPPENS INTERMIT.
Tech Comments: WARRANTY,I RAN IDS PERFORMANCE DIAG FOUND CODES P0470 ONLY, WHILE MONITORING PID MONITOR WHILE DRIVING FOUND THE MAP SENSOR IS WAY OUT OF RANGE, REPLACED MAP AND EBP RE TEST DROVE OK, AL PERFORMED STEPS 1 2 3 4 5 6 7 8 9 10A 12A 13 14 15
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 34 1H03 030008 5C3Z 9F452 AA D42 42 40620
AWS Claim Key: 11683378 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 07805 - * Name: PREMIER FORD LINCOLN MERCURY, INC. Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-2007 Doc #:59619401
Cust Comments: GUEST STATES THE ENGINE LACKS POWER SURGES AND BLOWS SMOKE WHILE DRIVING DIAG AND ADVISE
Tech Comments: WARRANTY,IRAN EEC DIAG FOUND THE TRUCK HAS NO POWER AND SURG ING WHILE DRIVING, IRAN PERFORMANCE DIAG FOUND THE FUEL PRESSURE 50 UNDER LOAD OIL SYSTEM PASS. RAN PIN POINT TESTS AND FOUND THE EGR VA RE TESTED FOUND THE MASS AIR AND EBP ALSO OUT OF RANGE WHILE DRIVING REMOVED AND REPLACED EGR VALVE AND EBP SENSOR RE TEST DROVE RE QUICK TESTED OK PERFORMED STEPS 1 2 3 4 5 6A 6B 8 10A 11 12A 13 15 I A
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 47 1H03 030008 4C3Z 9F452 A D42 42 54610
AWS Claim Key: 12842181 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:00166101
Cust Comments: GUEST STATES TRUCK CUTS OUT WHEN LETTING OFF THROTTLE; DIAG
Tech Comments: RAN EEC DIAG FOUND CODES P0401 P0404 P0405 P1335 RAN PINPT TESTS; REPROGRAMMED PCM TCM FICM TO LATEST CALI. REKOEO KOER EGR FAILS. REMOVED EGR VALVE FOUND PLUGGED UP REPL EGR VALVE ADN RE KOEO KOER ALL TESTS PASS AT THIS TIME. RETEST DROVE OK PERFORMED DIAG STEPS
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 47 2H02 030407 5C3Z 6F089 BA D21 42 54610
AWS Claim Key: 12816454 Trx Code: E72 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:00169401
Cust Comments: DRIVE D GUEST STATES THAT THE TRUCK BLOWS ALOT OF BLACK SMOKE, ALSO THE TRUCK DIES WHILE DRIVING. DIAG AND ADVI
Tech Comments: WARRANTY,RAN EEC DIAG FOUND CODES P0299 P0470 P0404 P0405 RAN PIN POINT TESTS REMOVED AND REPLACED VGT SNESOR, AND MASS AIR FLOW SENSOR RE TEST DROVE FOUND EBP VOLTAGE CHANGING ERRATIC REMOVED AND REPLACED EBP SENSOR AND REPLACED EBP WIRING CONNECTOR REPROGRAMED PCM, TCM, FICM, RE TESTED , FUEL PRESSURE OK 47 OIL SYSETEM PASS RE KOEO KOER ALL TESTS PASS
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 49 1F05 030306 4C3Z 8A616 AA D42 42 56071
AWS Claim Key: 12888870 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2008 Doc #:00269002
Cust Comments: LIGHT LINE GUEST STATES THE SERPENTINE BELT MAKES A CHIRPING NOISE AT IDLE DIAG AND ADVISE
Tech Comments: WARRANTY, RAN COMPLETE NVH DIAG FOUND BELT PULLEYS AND BELT GLAZZED AND WORN REMOVED FAN, FAN CLUTCH. REPLACED FAN CLUTCH REMOVED SERP BELT. DRIVE PULLEY AND TENSIONER AND WATER PUMP PULLEY RE TESTED RE ASSEMBLED RE TESTD OK
1FTSW31P04ED05494 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-APR-2004 17-SEP-2004 156556 USA 49 2H01 030407 4C3Z 9G489 AARM D42 42 56071
AWS Claim Key: 12886406 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 03288 - * Name: BRENT BROWN FORD LINCOLN MERCURY, LLC Ph: 801-2293600 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:08-SEP-2008 Doc #:00269001
Cust Comments: DRI/DEISEL DRIV GUEST STATES THE ENGINE SURGES AND LACKS POWER WHILE DRIVING DIAG AND ADVISE
Tech Comments: 4.0 081613F INTALLED TURBO REPLAMENT PARTS AS PER TSB
