checked out the neighbors truck,and if my code reader is right i have a p0087
"fuel rail pressure low". truck will lose power and might do 60 tops.
is this a comon problem? do the sensors go bad often or should i look somewhere else? help.
thanks
semi comon does he have a tuner or pull alot of trailers
try a shim kit form ppe its like $10 and if the problem persists a lift pump should fix it
the shim kit will stiffin the spring that allows to much fuel to be returned back to the tank the spring is just worn
that is just my idea for a fix
