So i am looking in to lifting the truck just a smidge so that i can put 35" tires on comfortably. I know that they will probably fit without rubbing on my stock setup. I have looked into the 2.5" leveling kits and have heard good things and bad about them. I have also looked into the 2.5" front and 2" rear lifts. Anyhow what I am trying to get at is if i lift the truck 2 or so inches what all gets out of whack and has to be adjusted for.
I know i probably need traction/ladder bars
track bar re-locator
caster adjustment?
as well the correct backspacing/offset for the tires so they don't rub or stick out too far.
Anything else that i am missing.
This is going to be expensive!
I did a ready lift sst leveling kit on my truck and have no issues whatsoever! I run 35" toyo on the stock 20 inch rim ( see picture ) great ride and easy install you won't have a y regrets
do you ahve any issues with the 35's on the stock 20s, meaning troubles balancing?
