I have an 2008 F-450, tail light is out, I have opened tail gate, removed 2 sheet metal screws. The lamp assembly appears to held onn by another fastener or two. I have looked in access holes on vehicle and do not see what is holding lamp. I know it minor but frustrating. Please respond with where to access and what is holding lamp in place. Thank you
Once you remove the 2 screws the assembly is held in place with rubber grommets and plastic post. It is a bit of a tug to get it out then you can remove the light assembly and change the light. It does require a bit of effort to remove the assembly do not know why it is such a tight fit.
