Standard Claims List For Model Year 2008
1FTSW20RX8EC41418 T/F7 F T/BC T/BD T/B A1 T/BE T/QL 19-SEP-2007 09-MAY-2009 121002 USA 0 1F01 030301 * 8009 * L87 53 15
AWS Claim Key: 1218489 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06617 - * Name: TIM STEWART FORD LINCOLN MERCURY Ph: 770-6210200 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2008 Doc #:06792802
Cust Comments: RECALL 08T01
Tech Comments: INSTALLED COOLING SYSTEM VENTURI TEE
1FTSW20RX8EC41418 T/F7 F T/BC T/BD T/B A1 T/BE T/QL 19-SEP-2007 09-MAY-2009 121002 USA 0 2G01 * * * * * * 16
AWS Claim Key: 1757196 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 06617 - * Name: TIM STEWART FORD LINCOLN MERCURY Ph: 770-6210200 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:07289101
Cust Comments: PROGRAM 08B07
Tech Comments: REPROGRAM THE PCM, TCM AND IC
1FTSW20RX8EC41418 T/F7 F T/BC T/BD T/B A1 T/BE T/QL 19-SEP-2007 09-MAY-2009 121002 USA 7 6J09 011401 * 11582 * D21 X2 8500
AWS Claim Key: 4901945 Trx Code: 2 Labor Hrs: 4
Dlr Cd-Sub Cd: 07815 - * Name: FRANK JACKSON SANDY SPRINGS FORD Ph: 770-6770700 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2009 Doc #:121219A
Cust Comments: CUST STATES TRUCK STALLED OUT WHILE DRIVING ON HIGHWAY 2 TIMES AND SURFACE STREETS MULTIPLE TIMES
Tech Comments: DIESEL ENG DIAG ROAD TEST OVER ROUGH ROAD BATTERY LIGHT FLICKERED CHK OASIS CONTACT HOTLINE REC TO CHK FOR U DTCS PERFORM WIGGLE TEST INSPECT WIRES FOR CHAFING RR RIGHT WHEEL AND INNER FENDER TO INSPECT RR BJB NO PROBLEM FOUND TRACE CIRCUIT CDC35 TO ALL RELATED CONNECTORS RR STEERING COLUMN COVERS FOUND CONNECTOR C250 NOT LOCKED AT IGN SWITCH RECONNECTO CLEAR DTCS ROAD TEST RETEST MC
