Does anyone know if the high idle to the upfitter switches works on the 09 the same as the 07. Are the wire colors the same?
Smokin
It does work but you can only use the pto wire the other way will not work tried both and the only one that works is the pto wire. Don't remember what color but it is labeled under the drivers side. I will check the color for you.
