So I am installing seatbelts out of a 2011 into my 2002 crewcab so that all 6 seats have shoulder harnesses. So far I have purchased a jump seat out of a newer truck and replaced the front. Now I have purchased the seat belt and brackets to put on the rear of the cab so the center will have a shoulder belt. I am waiting on the trim and the lower bracket that I had to order. Once I get the last pieces I will post the install and part numbers from Ford. :rock
Parts:
Bracket: 7C3Z-2522686-A
Reinforcement: 9C3Z-2540492-A
Retractor: 8C3Z-25611B64-CB
Screws: W505275-S437M
These are the parts I have so far. I am waiting for the bracket and trim piece to show up.3-5 days
Debating if I want to cut this off the reinforcement and mount it on the picture below. OR
Remove this entire piece and then weld the entire reinforcement in.
1223111106.jpg Reinforcement.
The biggest difference in the reinforcement is the guage of the metal. I think if I remove the main piece off of it and then weld it onto the existing part of the cab and plate it, I should not lose any strength.
Update
Drilled out all the welds to remove bracket.
Bracket
Welded them in place.
Waiting on the latch assembly that bolts to the floor of the cab and I will post the completed pictures.:knight
Parts list cont...
BC3Z-25601B32-AC TRIM COVER
BC3Z-2660045-AA SEAT BELT ***. ( This piece is needed because the end of the retractor does not bolt to the floor. Instead it latches so you can undo it on newer trucks to tilt the seat forward.)
FINISHED!!!
:knight Well I got the latch this afternoon and now this project is complete!
