Boost Junkie
Im getting ready to order my alcoa classic in 22" w/ shaved rears to keep the wheels even with the rear fenders. Im keeping the front stock height & want to lower the rear about 2" to somewhat level it out w/ the front. I dont want it perfectly level so when i tow my 31' travel trailer the rear isnt squatted lower than the front....SO, I was thinking of running a staggered tire height, 305/40/22 front & 305/45/22 rear. I know it wont look obvious as the rear will be sitting a tad higher so the larger gap will hide the 1" tire difference & this fitment will allow the gap to be a little closer with a short drop. Wanted to hear opinions on this set up....
Next, the rear drop. I have no idea whats involved here. Can somone enlighten me on a kit or procedure for doing this? Will either or both these changes (tires/drop) drasticallly effect my towing? (8k# trailer) I only tow the trailer about a half dozen times a year and dont travel more than a couple hundred miles for the furthest trip. I just want a nice clean street look while still being able to occasional tow when needed....
Iappreciate any input offered!
Boost Junkie
When I installed my rear 2" drop shackles it only dropped it about 3/4" to 1" at the VERY most.
thanx for your input. so what would you recommend? im just trying to drop the rear a bit to get closer to the front height but still want it a tad more high than the front as i mentioned, so it doesnt "bulldog" when i tow my trailer....are rear shackes the best way to lower the rear? will it hinder towing? thanx again!!
TDG Mafia Member#67
why not just go to a smaller block in the rear? it should be either 2" or 3.5" i think so if its the 3.5 go down to the 2, if its 2 go down to a 1...
Boost Junkie
Thanx 6l, I thought about the blocks but unless im wrong my non 4x4 dually has 2" from the factory wich will only give me a 1" drop at most. Ive heard a couple horror stories where the short blocks have cracked when towing. The one thing I do like about the shackles is the geometry once installed pretty much remains the same, or so I've heard......
Just to note, on a flat surface my trick currently stands (ground to bottom of fender lip) at 35 1\4" front and 38 3\4" rear. So you can see how I want a minimum of 2" prefferably 2.5 to 3.0 though......
I really appreciate all the input guys!
Get the leaf spring hangers from DJM, there are 3 holes and each one drops about a inch. My rear end is set on the middle setting.
Boost Junkie
thanx EJ, so can you use hangers by themselves w/o the drop shackles? that would be great....
Boost Junkie
Not sure if anyone is intersted but it may be good for anyone running across this thread in the future while doing a search on lowering thier superduty. You will need to adjust your pinion angle 6* when doing a hanger drop but no adjustments when adding the shackles. So if you looking for a couple inches of drop w/o the need for any additional adjustments to get your rear geometry correct just do the shackles......
Reactions: plainredtruck
