Up for sale is a 1934 Plymouth 4 suicide door rod project that i started on a couple of months ago. The car has ZERO rust. It has been in storage for the last 47 years. There has been a nova sub frame with rack and pinion steering grafted into the original frame and then it was sandblasted and painted .The front clip has been welded together for a tilt style and the side hood doors are still functional. The interior needs to be finnished and the driver door glass needs to be replaced. I pulled the car off of the frame and started to build a custom frame but it needs to be completed. I have another ford 9" and there is a 8" under the original frame. I cut the rear floor board for the custom frame but I kept all the metal if you want to weld it back in. The engine is a 270 dodge hemi that has new rings, bearings, cam, valves, seals, and gaskets. I have the title in hand.
I have boxes of parts that include headlights, taillights, brackets, hindges, etc. I can put the car back together i na about 2 hrs for transport. I would rather you call me if you have any questions @ 361-649-7240. I can deliver for $1.00 a load mile. I will consider all interesting trades.
sold
