Thanks to all in advance;
I just replaced a cyl hd on this old 7FB do to a small bolt left in #5 intake port, looked like it had been there for a very long time and finally wore down to lodge its self in valve and bent it. This engine is suppose to be a 310 hp the piston number are 9Y3116 what will be the best nozzles i can use to make it a better running engine. i will also be changing the turbo with one from a 3406E that i have on a block that thru a rod. Your info will be highly appreciated.
Your serial # and or arrangement # would help determine what pump cam it has and what it should be timed to.
Going by the piston number you gave its 15.2:1 compression with a high top ring location and is for 310hp or lower. You dont know what nozzles are in it currently do you?
